unable to fillet
All  1-4  5-8
9772.5 In reply to 9772.4
the 2 borders ( in your piece ) are composed with small segments ... you need to use Join to obtain 2 perpendicular lines
and then large fillet can be applied
9772.6 In reply to 9772.4
As corchet said, it is because of that broken edge.
So select any edge, press Ctrl + A to select all and use the Merge command.
9772.7 In reply to 9772.6
Also if you select the whole object and run Merge that will also target all the edges of the object.
9772.8
Thanks all for the tips!
wim
Show messages: All  1-4  5-8
