unable to fillet
All
1-3
4-8
corchet
20 Apr 2020 (4 of 8)
9772.4
In reply to
9772.3
problem in your piece ( the small yellow line )
select the segments and join them
then extrude and fillet
file joined
EDITED: 28 May 2020 by CORCHET
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
corchet
20 Apr 2020 (5 of 8)
9772.5
In reply to
9772.4
the 2 borders ( in your piece ) are composed with small segments ... you need to use Join to obtain 2 perpendicular lines
and then large fillet can be applied
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Stargazer
20 Apr 2020 (6 of 8)
9772.6
In reply to
9772.4
As corchet said, it is because of that broken edge.
So select any edge, press Ctrl + A to select all and use the Merge command.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Michael Gibson
20 Apr 2020 (7 of 8)
9772.7
In reply to
9772.6
Also if you select the whole object and run Merge that will also target all the edges of the object.
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
wimverbe
21 Apr 2020 (8 of 8)
9772.8
Thanks all for the tips!
wim
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-3
4-8
