unable to fillet
9772.1
I am trying to fillet the outer corner of this object, but it is not working, not even with a smaller radius. I separated it, looked at the individual elements, but can't find a flaw...
Moi V3
Size: 36.5 KB, Downloaded: 25 times, Dimensions: 511x439px
9772.2 In reply to 9772.1
this ?
select the necessary lines ... copypaste ... trim to delete parasites segments ... extrude ... filet
EDITED: 28 May 2020 by CORCHET
9772.3
it is about this edge which cannot be filleted:
I don't quite follow your described workflow...
Size: 29.2 KB, Downloaded: 22 times, Dimensions: 374x469px
9772.4 In reply to 9772.3
problem in your piece ( the small yellow line )
select the segments and join them
then extrude and fillet
file joined
9772.5 In reply to 9772.4
the 2 borders ( in your piece ) are composed with small segments ... you need to use Join to obtain 2 perpendicular lines
and then large fillet can be applied
9772.6 In reply to 9772.4
As corchet said, it is because of that broken edge.
So select any edge, press Ctrl + A to select all and use the Merge command.
9772.7 In reply to 9772.6
Also if you select the whole object and run Merge that will also target all the edges of the object.
9772.8
Thanks all for the tips!
wim
