Flow command
 1-2  3-22
9766.3 In reply to 9766.2
1) I have selected the surface
2) Flow
3) selected the center line of the right surface
4) selected the line on the left surface
Usually I project a curve on the surface .... then I cut and lower the cut surface and use the blend command but I had problems with the shape of the cut which is quite pointed in the ends ... for this I asked if there is a specific command or a technique that maybe I don't know
9766.4 In reply to 9766.3
give a volume to your curved plane with Offset shell
draw a crack with Freeform tool then project on the curved offseted plane
extrude the draw crack
finaly make a boolean merge and delete the faces to see through the curved plane
EDITED: 28 May 2020 by CORCHET
9766.5 In reply to 9766.4
Hello corchet .... I know the procedure .... I have to make a bend in the surface .... I can do the hole ... maybe I explained myself wrong I wanted to know if there is a command that closes the hole creating me a crack but closed not open.
Usually I cut the surface then I lower it and finally use the blend command but this shape must necessarily be pointed like on both sides and I thought of making that shape to intersect with the surface and then subtract it and then use fillet but I can't place it on the surface
9766.6 In reply to 9766.5
ok ;)
draw 2 separate line to figure the borders of the crack
draw a small arc to join the 2 borders of the crack ( not flat ) in a perpendicular plan
select the small arc and choose the sweep command
select the 2 rails ( borders of the crack )
so you'll get a crack with a volume
place this on your curved surface
boolean union if neccessary
9766.7 In reply to 9766.6
i try also Nsided command but it gives unpredictable results sometimes fun sometimes crap ;)
9766.8 In reply to 9766.7
the borders of the crack can be distorted with a script " distortcurves"
with this script you can add deformation ( just a little bit 0.1 on one or 2 axes )
look at the right
9766.9 In reply to 9766.8
here you go
http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=8440.1
place files in moi3d command folder
9766.10 In reply to 9766.1
Hi Tony, curve to curve flow won't work for that because it does not know how to align itself to the surface normal. That might be possible to add as an option in the future.
Surface-to-surface flow might work for you here though, check out this thread for an example:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7516.1
Tricky methods!
EDITED: 17 Apr 2020 by PILOU
9766.12 In reply to 9766.11
Thanks Michael excellent I try now .... if I can post here another problem I have with Flow .... I would like to place those two screws on the red curve to the gray surface but I can't ... I don't know if I'm wrong.
I tried with orient but it doesn't position me well ... how can I do it?
9766.13 In reply to 9766.12
Sorry here are the files
Size: 884.7 KB, Downloaded: 50 times, Dimensions: 1600x1200px
9766.14 In reply to 9766.13
Hi Tony, how are you wanting to place them, should it be like a projection? But with a projection onto an angled surface or with Flow, the result will have deformation in it like getting stretched out.
Do you want it something more like projecting the center point of it onto the surface and then having the knob not be deformed but only rotated to align with the surface normal?
9766.15 In reply to 9766.13
Surfaces have a "Normal" snap. So I can draw a line in the normal.
I then can use copy with origin and PastePart to set my object on the surface, facing the right direction.
9766.16 In reply to 9766.15
Yes Michael
9766.17 In reply to 9766.16
Hi Tony, I'd probably draw a line down the projection direction like this:
Now select the line and the surface and then use Construct > Curve >Isect. That will generate a point at the spot on the surface you want to snap on to using Orient:
To use orient, select your knob, run Transform > Orient, place the base point onto the bottom of the knob, right click since you don't need to set any base rotation. Then for the target point place it on the point that was made with the intersection, and then right click to finish since you don't need to do any rotation there either. So that's 4 clicks total, left click on the base point, right click to end rotation picking, left click on the target point, right click to end rotation picking there.
Note that it will initially look like the knob isn't on the surface, but that is just a display artifact since the surface has a rough display mesh in that particular area. If you export to a polygon mesh format you will be able to see it better. Here is a screencap video:
Note that the bottom of the knob is planar but the surface is curved. If you plan to cut a hole in the surface you would probably need to push it in a bit further so it fully intersects with the surface.
9766.18 In reply to 9766.17
Thanks Michael
How do you view that sideways mesh view command you see in the video?
9766.19 In reply to 9766.18
Hi Tony,
I have a keyboard shortcut set up to save to a polygon mesh format, the shortcut is set up like this:
SaveAs c:\test.obj
9766.20 In reply to 9766.19
Thanks Michael
9766.21 In reply to 9766.20
Michael what kind of settings do you recommend for eportation for surfaces that are regular enough for rendering?
9766.22 In reply to 9766.21
Hi Tony,
Well it depends on the particular geometry involved.
The main thing to use is the angle parameter - that measures the angle between surface normals at polygon vertices and if it is beyond that angle value it will subdivide it further. So for example an angle value of 5 will subdivide until surface normals are less than 5 degrees apart. This will make a denser mesh in areas with tighter curvature.
However, a surface that is pretty large but also only shallowly curved (like you have here for example) can not get enough refinement from the angle measurement alone. For that case then you want to introduce additional dividing by using the "Divide larger than" parameter. That takes a distance value and subdivides polygons that are larger than that distance across. So you want to put in some value proportional to your overall object size like if your object is 10 units across try a "divide larger than" of 0.1 and see if that gives you enough refinement or not. If not go lower in steps.
But generally start by moving the slider around which controls the angle parameter.
Show messages:  1-2  3-22
