Flow command
 1-14  15-22
9766.15 In reply to 9766.13
Surfaces have a "Normal" snap. So I can draw a line in the normal.
I then can use copy with origin and PastePart to set my object on the surface, facing the right direction.
9766.16 In reply to 9766.15
Do you want it something more like projecting the center point of it onto the surface and then having the knob not be deformed but only rotated to align with the surface normal?
Yes Michael
9766.17 In reply to 9766.16
Hi Tony, I'd probably draw a line down the projection direction like this:
Now select the line and the surface and then use Construct > Curve >Isect. That will generate a point at the spot on the surface you want to snap on to using Orient:
To use orient, select your knob, run Transform > Orient, place the base point onto the bottom of the knob, right click since you don't need to set any base rotation. Then for the target point place it on the point that was made with the intersection, and then right click to finish since you don't need to do any rotation there either. So that's 4 clicks total, left click on the base point, right click to end rotation picking, left click on the target point, right click to end rotation picking there.
Note that it will initially look like the knob isn't on the surface, but that is just a display artifact since the surface has a rough display mesh in that particular area. If you export to a polygon mesh format you will be able to see it better. Here is a screencap video:
Note that the bottom of the knob is planar but the surface is curved. If you plan to cut a hole in the surface you would probably need to push it in a bit further so it fully intersects with the surface.
9766.18 In reply to 9766.17
Thanks Michael
How do you view that sideways mesh view command you see in the video?
9766.19 In reply to 9766.18
Hi Tony,
I have a keyboard shortcut set up to save to a polygon mesh format, the shortcut is set up like this:
SaveAs c:\test.obj
9766.20 In reply to 9766.19
Thanks Michael
9766.21 In reply to 9766.20
Michael what kind of settings do you recommend for eportation for surfaces that are regular enough for rendering?
9766.22 In reply to 9766.21
Hi Tony,
Well it depends on the particular geometry involved.
The main thing to use is the angle parameter - that measures the angle between surface normals at polygon vertices and if it is beyond that angle value it will subdivide it further. So for example an angle value of 5 will subdivide until surface normals are less than 5 degrees apart. This will make a denser mesh in areas with tighter curvature.
However, a surface that is pretty large but also only shallowly curved (like you have here for example) can not get enough refinement from the angle measurement alone. For that case then you want to introduce additional dividing by using the "Divide larger than" parameter. That takes a distance value and subdivides polygons that are larger than that distance across. So you want to put in some value proportional to your overall object size like if your object is 10 units across try a "divide larger than" of 0.1 and see if that gives you enough refinement or not. If not go lower in steps.
But generally start by moving the slider around which controls the angle parameter.
Show messages:  1-14  15-22
