Problem to create a surface with rectangular base to semiellipse base and fillet
All  1-5  6-14
9765.6
if you copy paste some borders of your piece ... and zoom ... you'll find small hole ... and so no fillet possible
draw profile & offset ( small or large ) sweep an arc along the profiles
this give couvercles ( rectangular and semi circle )
then loft between profile
you can do various size of sweep sections to obtain large or small fillets
EDITED: 28 May 2020 by CORCHET
9765.7 In reply to 9765.6
file here
9765.8
attached is a method that allows for the 0.25 radii prior to adding a fillet.
Create a elliptical arch and a goal post loft using the exact option.
Loft the side edges,join surfaces then planar to close to a solid.
Add 0.25 radii then select edges to fillet and apply fillet size you require.
Hope this helps
Barry
my proposition is :
Fileting before lofting...
You filet your profiles.
You loft without cap.
You use a blendcap.
9765.10 In reply to 9765.9
Brilliant!
9765.11
why not just built it with a variable fillet? front is a fillet on the corners then the bottom edges minis the very back edge you run a small fillet and then with the same operation make your larger fillet as a variable and then finish up with the rest a as a small fillet. so make a box with three fillets.
EDITED: 30 Jan 2022 by VAL2
9765.12 In reply to 9765.11
The problem with variable radius fillet is it will leave the end profile as a rounded rectangle instead of an ellipse shape.
9765.13
If the arch at the back is the most import criteria then I would do a simple loft of two lines, trim the loft for the front radius make it's mate as a plane loft the two planes together (leaving enough room for a fillet) and then fillet the whole thing.
9765.14
I really appreciate all techniques! Now i'm going to try all!
Thanks!
Show messages: All  1-5  6-14
