shortcut menu
 1-6  7-26  27-46  47-49
9758.47
Hi All!
I have now found a feasible way to personalize the SidePane1. Important in situations where the brain is not able to keep up with late evening or stress.
I will use SidePane1 in the future mainly for much used special functions and scripts, the instructions for which are recorded in the command reference. I will call the help in cases where no anchor word is given (scripts) via the renamed command line.
duplication of command line, renamed to Help.htm and Help.js, generated at Button and F1
"file:///C:/Program%20Files%20(x86)/MoI%203.0/docs/moi_command_reference_German.htm#help" and finds anchors in the help document.
Then I wrote a list of the partly self-designed buttons in the command reference, which in turn find anchor words themselves, so that a description can be found quickly.
If only F1 is pressed, or no immediate redirection takes place, you end up in the slightly rewritten help, which again leads to the self-designed extension of the command reference.
The way is unusual, but the result is sufficient.
I hope my translator didn't twist too much.
Best regards and many thanks
Franz
9758.48
Hi hl and all!
The script with the additional menu SidePane1 is very helpful in the application.
Would it be possible to complete the script so, that the window opens at a desired position, maybe in the upper left window border?
Thanks a lot
Franz
9758.49 In reply to 9758.48
Hi Franz,
Sorry, no there isn't a way set up currently for a script to do that. I'll see about adding it in.
Show messages:  1-6  7-26  27-46  47-49
