shortcut menu
 1-2  3-22  23-42  43-49
9758.3 In reply to 9758.1
Hi hl & Pilou -
It looks like the screenshot above is for v3. One of the differences between v3 and v4 is that the newer WebKit HTML engine in v4 is not as tolerant of malformed HTML structure like missing element close tags.
There's a missing <table> </table> and a few missing </td> closing tags, with those added in it should then work with MoI v4. Here's a tuned up file attached here.
Thanks for sharing it hl!
EDIT: also applied tweak to remove empty text line on the command buttons.
EDITED: 7 Apr 2020 by MICHAEL GIBSON
9758.4 In reply to 9758.1
Hi hl, also I noticed it uses one icon that is not part of the standard MoI install PipeIcon.png . Could you please post that .png file too so if someone wants to use it they can also copy PipeIcon.png in the the /ui/icons folder.
In the file attached above I also added this:
	<style>
		/* Turn off text block under command button icon */
		moi\:CommandButton > div {
			display:none;
	</style>
Which should turn off the space for text underneath the command buttons.
Thanks, - Michael
9758.5 In reply to 9758.3
That was that ! Bravo!
And the marvelous is that you can move this Floating window to the other monitor!!!
Here Moi is on my Portable Computer, Floating Window on my external Monitor
Of course I can make the inverse because my monitor is some bigger that my portable PC ! :)
Image don't show the true size reality! :D
Curious that was not made before ?
EDITED: 7 Apr 2020 by PILOU
9758.6
Nice script hl - thank you!
Hi Pilou, I misunderstood your pic at first - I thought you just created for us a beautiful Totem Pole of MoI :)
...but it would make an interesting project for one of our resident artists - 3D printable ideally - with the MoI head to top - any objetions Michael?
Thanks Michael for the tweak to hl's script - I still don't know where you find time to do product dev and reply to so many posts. BTW, we must owe you some money for all the V4 upgrades by now? I'm just getting back into MoI after a long period on other non-CAD projects, but MoI never looses its appeal, thank you!
Hamish
9758.7 In reply to 9758.6
Hi Hamish!
No objections, it sounds like a fun project!
Not yet, there's still one more beta to go with a last set of bug fixes and export for dimensions.
9758.8 In reply to 9758.6
@ HairyKiwi Yes that was also a very pretty totem! :)
Does it possible to have text under the icons ?
9758.10 In reply to 9758.1
Thanks a lot
simply genius !
can be use with FullScreen for people who use 2 screen
9758.11 In reply to 9758.10
sure very cool! ;)
Here the file to put inside folder command and make a shortCut FullScreen or press Tab ad write Fullscreen (Fullscreen, FUllScreen etc)
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=519e833721d1b435aa1f6a2f8590a4b0&filename=FullScreen.js
Strange Thing about using the fullscreen script.
All is right using it 7 or 8 times then, MOI is blocked ?
Is it mine version or a general problem ?
I use beta 4.0 01/22
9758.13 In reply to 9758.9
In this particular version hl has removed all the text so you would need to add it back, the text content goes inside the moi:CommandButton elements, like where the TEXT is shown here: <moi:CommandButton>TEXT</moi:CommandButton>
9758.14 In reply to 9758.12
Hi Phiro,
Can you give a little more detail about what you mean by "blocked" ? Are you able to move viewports and the screen redraws or is it totally frozen ?
9758.15 In reply to 9758.14
The application is totally frozen.
Viewports don't move.
I must use the process manager to kill it.
Each time I call the script the process use 10Mb more memory.
When I launch MOI, process uses about 60Mb. After using the script 7 or 8 times, the process use 150Mb and is frozen.
OK :) I have changed display:none;..........in display:yes;....not sure that must be that but that works :)
<style>
display:yes;
</style>
Another thing here the French translation but how to make the English for be call in Options ?
Possible or not : so 2 versions that i enable or not manually ?
9758.17 In reply to 9758.15
Hi Phiro,
The most likely thing is a video driver bug which is triggered by the viewport resizing.
First thing to check would be to get the latest video driver from the manufacturer's web site and see if that solves it.
9758.18 In reply to 9758.16
It's possible to do this using <moi:Text> elements instead of hard coded text.
A <moi:Text> element will look up text from the string table of the current active language.
So for example with the first one you would put <moi:Text textid="Line"> in the text location.
That will then look up the entry with a left-side value of Line= inside the current Strings.txt string table, so that would come from EnglishStrings.txt if the current language is English, or FrenchStrings.txt if the current language is French.
9758.19 In reply to 9758.18
Absolutly perfect!
<moi:CommandButton icon="moi://ui/icons/LineIcon.png" command="line"><moi:Text textid="Line">Ligne</moi:CommandButton>
Hum hum :) (for beta 4)
Icon for pipe works fine (personal icon ;)
But text not so good...
I try to make the first line (10 icons)... French /English but not total success! :)
Some stay empty!
I don't believe i had made some type errors ???
http://moiscript.weebly.com/uploads/3/9/3/8/3938813/sidepane1.htm
9758.21 In reply to 9758.4
I forgot an icon. It's made by myself
9758.22 In reply to 9758.19
Almost - it would be good to put a "self-closing" slash on the <moi:Text> and since it will supply the text you don't want any additional text in there.
So you would want it like this:
<moi:CommandButton icon="moi://ui/icons/LineIcon.png" command="line"><moi:Text textid="Line" /></moi:CommandButton>
Show messages:  1-2  3-22  23-42  43-49
