Moi3d Blender Bridge
All  1-6  7-10
9757.7 In reply to 9757.5
Tried BMOI Connector, and indeed, it works nicely.
Michael, I'd really advise you to consider adding such a bridge between MoI and Blender into MoI natively. I'm sure it will attract the attention of the rapidly growing Blender user base.
EDITED: 7 May 2021 by METIN_SEVEN
9757.8 In reply to 9757.7
Hi Metin,
if you install Max's UI the BMOI Connector appears in the bottom panel.
Barry
9757.9 In reply to 9757.4
Hi Metin,
Do you happen to know if it does work with windows 7 as well?
On the Github link it says it works with windows 10!
9757.10
Thanks Barry. Yes, it took me a moment to discover those buttons, but the BMOI Connector bridge works quite nicely. Too bad it doesn't export curves as SVG to Blender. That's undoubtedly because MoI doesn't include SVG export yet.
Psygorn, I don't know if it works on Windows 7 as well, sorry. You'd think it should work, but the Github page mentions the necessity of the Temp folder's default path, so you might want to check if that path is exactly the same in Windows 7.
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
Show messages: All  1-6  7-10
