Sphere Sweep, Canal Surface
All  1-3  4-7
I wrote a canal surface/sphere sweep script, but it did not work.
MoI did not like my vector math, which was likely due to my error(S). :-)
It is hard to understand the vector/scalar formulas in various math papers. Notations vary.
I'll revisit the faulty script, but first, have reverted to a special case of the spheres/envelope being tangent to the plane z = 0.
For this simple case, the characteristic circles for the modWedge can be manually built in MoI4, say for 21 points, by using tangents and mirror and circle factory and Loft.
I'm slowly working on a simple script version...
The sphere sweep is often NOT the same as a circle sweep.
(The resulting modWedge does not like to boolean union or trim with the Reuleaux tetrahedron, which is another story.)
The new MoI4beta curve methods, such as crv.dropPoint( pt ),
and crv.evaluateTangent( t, 2 ) are very useful.
So: Is the second derivative at NURBS parameter "t" associated with point on the curve <<<Equivalent>>> to the Normal at the point ?
(un_normalized) ?
EDITED: 25 Apr 2020 by BEMFARMER
9755.5 In reply to 9755.4
No, but they are related. The curvature vector is calculated from the first and second derivative.
9755.6 In reply to 9755.5
Thank's Michael,
Back to vector math calculus class for me :-)
Todays idea is to perform a sphere sweep on a curve, using Flow.
Unwrap the curve.
Sphere radii vary along the arc length.
The envelope, for the unwrapped curve (straight line), is a surface of revolution.
The rate of change of the radii equation with arclength to be limited by ?
To get the planar curve to revolve... ???
EDITED: 18 May 2021 by BEMFARMER
Show messages: All  1-3  4-7
