Car modelling
 1-12  13-32  33-52
9749.33
The problem with Michael's approach is that it is too simple. I said this in the case of a sailboat hull. If you just want something that sort of looks like something, you can use a simple method. But real hulls and real car bodies have very complex shapes that require a more difficult method. The beauty of MOI is that it gives us the tools to create Any form, and thereby get what We want, and not just a mathematical convenience. The trouble with most of these car and boat models is that the guys are working from 2D pictures and they really don't know what the "right" shape should be. If you have a lot of photos of the real thing, you can make it look right, but it's going to be a long, difficult process. But I don't want to discourage anyone. The satisfaction that comes from doing anything is proportional to the difficulty. What I want to tell those who are interested in this work is that MOI is the right tool, you just have to learn to use it.
9749.34 In reply to 9749.33
Hi Tim .... what technique would you use to draw it?
Another approach
9749.36 In reply to 9749.35
Hi Tony
A good idea could be to post the entire car, i mean the picture you posted in the beginning,not just a part of it
Are you modeling a real car or a concept?
Burr,as usual,showed us a good solution
I suggest you to follow Zarkow's method,it allow you to do more complex shapes,like actual cars
You have also ED's method,using Max Subd inside Moi
Here two links to other methods
take a look at the Vimeo video inside first to have more ideas
http://moi3d.com/forum/index.php?webtag=MOI&msg=5601.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6512.1
Once again,this is modeling for fun,not for manufactoring ;)
M
9749.37 In reply to 9749.36
Hi Mauro ... here is the whole car
https://it.wikipedia.org/wiki/File:Peugeot_206_02.jpg
and thanks for the tutorials .... really be done !!
EDITED: 7 Apr 2020 by TONY77
9749.38
I keep repeating there are no tricks, but only a lot of construction work, this example is made trying to create decent curves for the contours of the surfaces, it is nothing exceptional but it makes you understand the right method, I see many who propose work flows, with subdivision surfaces but so you lose any kind of precision in creating surfaces ..
9749.39 In reply to 9749.38
And the last thing take a look on the professional high-end software for car surfacing like ICEM surf or alias, below some video where you can see the hard work needed to get a well smoothed surfaces.
icem surf bmw x6 2009 side repeater modeling
Autodesk Alias Tutorial - Car Modeling in Alias Part 1
EDITED: 8 Apr 2020 by PAFURIJAZ
9749.40 In reply to 9749.36
Zarkow. Yes, Zarkow. Find the Zarkow video's.
His work is very clean.
9749.41 In reply to 9749.40
If I'm not mistaken are the videos that Pilou posted
9749.42 In reply to 9749.41
In the Wikipedia image of the car you posted, That beam area runs along the entire path. It is just cutoff by the headlight cutout.
So trying to model that beam to stop short is making it difficult on yourself.
In Michaels method shown, you would just make a headlight object to cutout to "Stop the beam"..... It is ok to have it go past the point, initially....
9749.43 In reply to 9749.42
Yes burrman I tried in various ways but I can't ... I'll try again :)
Message 9749.44 deleted 8 Apr 2020 by MICHAEL GIBSON
For patient before the soon tuto bout the above Jaguar model...
This one is made in pure Moi modeling (not by me:) with principally Gordon's function!
He's got 45 more to go!!! I will put the original size when tuto will be released ;)
EDITED: 8 Apr 2020 by PILOU
9749.46 In reply to 9749.45
Thank's Pilou ;)
9749.47
I found a way , move the point to build the surface of the car fender.
9749.48 In reply to 9749.47
Thank's hl (FEIRUI445) I will also try this method ... thanks
9749.50 In reply to 9749.49
Thanks Pilou :)
9749.51 In reply to 9749.50
Sorry Pilou what is it about the gordon feature?
9749.52 In reply to 9749.51
The author said he used principally NetWork Moi Function (in French Moi version = Gordon ) ;)
Show messages:  1-12  13-32  33-52
