Car modelling
 1-6  7-26  27-46  47-52
9749.27 In reply to 9749.24
I've been helping over e-mails as well and the approach I'm suggesting is to make areas that have one broad shape that should be smooth out of larger extended surfaces and then the transition between them is done by fillets.
That can go something like this:
Sweep:
Network:
Surface/surface fillet:
Trim all to these common cutting lines:
9749.28 In reply to 9749.27
Pretty cool stuff.
I would also conquer for Tony that even if "beam crease" detail works for him, that THIS (Michaels demonstration) is really more what he should be working towards....
2 cents
9749.29 In reply to 9749.28
Meanwhile, thanks to Burrman for all the valuable advice ..... as for Michael's approach, it is very valid and I tried it directly on the model .... but, certainly because of me, it does not give me back the shape right.
The space between the upper quadrant of the mudguard and the small one is why the shape is not found .... if you see the space of the fold (mirror side) it is practically nothing .... if I use the sweep to create that small space then not I can get to the bigger bend ..... obviously maybe it's me who doesn't know the right technique .... that's why I'm asking for help :)
Size: 127 KB, Downloaded: 25 times, Dimensions: 840x569px
Size: 117.4 KB, Downloaded: 40 times, Dimensions: 750x630px
9749.30 In reply to 9749.29
The fact is that if you need a surface passing troughs a ideal shape you need to make the construction lines to guide your surfaces, with moi3d you can do well that but not in magic way but drawings the nurbs curve that define the boundary of your shapes.
9749.32 In reply to 9749.31
Thanks Pilou for the tutorial .... my problem is bodywork because everything else is able to shape it (or at least I think :)) in particular that front bumper and the rear part (which however seems to have almost succeeded). ... but the front just can't do it :)
9749.33
The problem with Michael's approach is that it is too simple. I said this in the case of a sailboat hull. If you just want something that sort of looks like something, you can use a simple method. But real hulls and real car bodies have very complex shapes that require a more difficult method. The beauty of MOI is that it gives us the tools to create Any form, and thereby get what We want, and not just a mathematical convenience. The trouble with most of these car and boat models is that the guys are working from 2D pictures and they really don't know what the "right" shape should be. If you have a lot of photos of the real thing, you can make it look right, but it's going to be a long, difficult process. But I don't want to discourage anyone. The satisfaction that comes from doing anything is proportional to the difficulty. What I want to tell those who are interested in this work is that MOI is the right tool, you just have to learn to use it.
9749.34 In reply to 9749.33
Hi Tim .... what technique would you use to draw it?
Another approach
9749.36 In reply to 9749.35
Hi Tony
A good idea could be to post the entire car, i mean the picture you posted in the beginning,not just a part of it
Are you modeling a real car or a concept?
Burr,as usual,showed us a good solution
I suggest you to follow Zarkow's method,it allow you to do more complex shapes,like actual cars
You have also ED's method,using Max Subd inside Moi
Here two links to other methods
take a look at the Vimeo video inside first to have more ideas
http://moi3d.com/forum/index.php?webtag=MOI&msg=5601.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=6512.1
Once again,this is modeling for fun,not for manufactoring ;)
M
9749.37 In reply to 9749.36
Hi Mauro ... here is the whole car
https://it.wikipedia.org/wiki/File:Peugeot_206_02.jpg
and thanks for the tutorials .... really be done !!
EDITED: 7 Apr 2020 by TONY77
9749.38
I keep repeating there are no tricks, but only a lot of construction work, this example is made trying to create decent curves for the contours of the surfaces, it is nothing exceptional but it makes you understand the right method, I see many who propose work flows, with subdivision surfaces but so you lose any kind of precision in creating surfaces ..
9749.39 In reply to 9749.38
And the last thing take a look on the professional high-end software for car surfacing like ICEM surf or alias, below some video where you can see the hard work needed to get a well smoothed surfaces.
icem surf bmw x6 2009 side repeater modeling
Autodesk Alias Tutorial - Car Modeling in Alias Part 1
EDITED: 8 Apr 2020 by PAFURIJAZ
9749.40 In reply to 9749.36
Zarkow. Yes, Zarkow. Find the Zarkow video's.
His work is very clean.
9749.41 In reply to 9749.40
If I'm not mistaken are the videos that Pilou posted
9749.42 In reply to 9749.41
In the Wikipedia image of the car you posted, That beam area runs along the entire path. It is just cutoff by the headlight cutout.
So trying to model that beam to stop short is making it difficult on yourself.
In Michaels method shown, you would just make a headlight object to cutout to "Stop the beam"..... It is ok to have it go past the point, initially....
9749.43 In reply to 9749.42
Yes burrman I tried in various ways but I can't ... I'll try again :)
Message 9749.44 deleted 8 Apr 2020 by MICHAEL GIBSON
For patient before the soon tuto bout the above Jaguar model...
This one is made in pure Moi modeling (not by me:) with principally Gordon's function!
He's got 45 more to go!!! I will put the original size when tuto will be released ;)
EDITED: 8 Apr 2020 by PILOU
9749.46 In reply to 9749.45
Thank's Pilou ;)
Show messages:  1-6  7-26  27-46  47-52
