can we do this at some point?
 1-20  21-26
9747.21 In reply to 9747.18
> I replaced the UpDate function in the FlowExtendSrf.js file.
It looks like the files in your FlowExtendSrfMoI3.zip are the original versions not the updated ones?
Here's the updated file attached.
9747.22 In reply to 9747.21
Cool! I have missed the new version :)
Works even inside the Infinite Trial version 3 without save!
9747.23 In reply to 9747.21
Thank you Michael.
I made the changes, but somehow the changes went sideways.
This is not the first time I have had trouble with Notepad++ when reusing and modifying copies of files.
I'll have to be more diligent :-)
9747.24 In reply to 9747.23
No problem Brian! You might have gotten bit by a permissions issue. Files inside the c:\Program Files (x86) folder are restricted to be read only at the standard privilege level. If you right-click Notepad++ and use "Run as administrator", it will run at an elevated privilege which is then allowed to make changes to files in c:\ Program Files (x86)
9747.25 In reply to 9747.24
Yes :-)
9747.26
Thanks a lot Michael for the plug-in ! It's great.
Show messages:  1-20  21-26
