can we do this at some point?
 1-17  18-26
9747.18 In reply to 9747.17
I replaced the UpDate function in the FlowExtendSrf.js file. (or thought I did...)
Edit: Deleted this faulty post.
EDITED: 5 Apr 2020 by BEMFARMER
9747.19 In reply to 9747.18
<< BUT, running the modified script in MoI3 resulted in (endless?) calculating process.
That was the same with the original for the V 3!
And the same with this update, (infinite calculus) there is surely a little bug somewhere...
EDITED: 5 Apr 2020 by PILOU
9747.20 In reply to 9747.17
> Cool! But in what path file is this UpDate function? (for be sure)
Well the plugin only has 2 files for it, FlowExtendSrf.js and FlowExtendSrf.htm, and only one of those has an Update() function - FlowExtendSrf.js . That's the one that needs the new code.
9747.21 In reply to 9747.18
It looks like the files in your FlowExtendSrfMoI3.zip are the original versions not the updated ones?
Here's the updated file attached.
9747.22 In reply to 9747.21
Cool! I have missed the new version :)
Works even inside the Infinite Trial version 3 without save!
9747.23 In reply to 9747.21
Thank you Michael.
I made the changes, but somehow the changes went sideways.
This is not the first time I have had trouble with Notepad++ when reusing and modifying copies of files.
I'll have to be more diligent :-)
9747.24 In reply to 9747.23
No problem Brian! You might have gotten bit by a permissions issue. Files inside the c:\Program Files (x86) folder are restricted to be read only at the standard privilege level. If you right-click Notepad++ and use "Run as administrator", it will run at an elevated privilege which is then allowed to make changes to files in c:\ Program Files (x86)
9747.25 In reply to 9747.24
Yes :-)
9747.26
Thanks a lot Michael for the plug-in ! It's great.
Show messages:  1-17  18-26
