MOI Amazing
All  1-6  7-10
9743.7 In reply to 9743.6
Hi Tim, if you can post your modified CommandBar.htm and SidePaneFilename.htm files here as a file attachment I can check them out to see if they are set up ok.
> but even after replacing the command bar htm I am still missing the full screen toggle?
The full screen toggle is only shown if the window is maximized and on a screen that has a Windows taskbar on it. If your window is not maximized or not on a monitor with a task bar then it is normal that it will not show up.
9743.8 In reply to 9743.7
I appreciate it but I am going to go ahead and buy the program this week and work with moving the entire main bar to the top and doing so I won't have to be concerned about adding some more buttons that I might want from the custom ui setup. If there are any issues then I'll be sure to post them here.
It really is a great product and a great value so I'm on board.
Tim
9743.9
Really loving this program.
I just discovered that you could click on the style and the dimensions under the Naming input but the pop up keypad doesn't seem to work there.
I'm working with pen tablets otherwise not an issue at all.
Thanks for any help
9743.10 In reply to 9743.9
Hi Tim, yes the popup is intentionally disabled on those controls. I guess at the time I thought it looked a little strange on that small popup and I decided to focus that particular area on keyboard input.
Show messages: All  1-6  7-10
