Ramiro
All  1-3  4-5
9742.4 In reply to 9742.2
I using 3.0 Beta version
9742.5 In reply to 9742.4
Hi Ramiro,
The problem is that the 3.0 Beta version is old and has long since expired. The only way to run it is by using a "cracked" version that has been modified to have the expiration removed and it's those modifications that is causing the MoI exiting problem that you are running into.
If you have a MoI license then make sure you are using the final release version of v3 which you can get by putting in your license key at http://moi3d.com/reinstall.htm and also the v4 beta release is available at http://moi3d.com/beta.htm .
Show messages: All  1-3  4-5
