Flow
All  1-3  4-6
9741.4 In reply to 9741.3
Ok I solved ..... I had copied in MOI 3D and not in version 4 :)
9741.5 In reply to 9741.3
Hi Tony, that error means that the script file was not found and it's attempting to run the text as directly script code itself.
There should be a file UnwrapCurve.js that you need to copy into a commands folder so that MoI can find it.
Are you running on Windows or Mac?
EDIT: Looks like you've got it figured out. For MoI v4 you can also copy it into the appdata commands folder, if you do that then new installs of MoI will find it there and you won't have to copy it into the program folder on each new release.
9741.6 In reply to 9741.5
Thanks Michael
Show messages: All  1-3  4-6
