Flow - lack of precision
All  1  2-4
Seems I have not these disjonctions...
Look how I have made
My start line is on the middle of the boxes
My circle is created with the length circum wanted so no stretch necessary
I have only 60°, 60°, 60° on the middle angles
EDITED: 23 Mar 2020 by PILOU
9733.3 In reply to 9733.1
Hi Mike, if you're using surface-to-surface flow mode then the problem is that surface to surface mode maps between the UV coordinate spaces of surfaces. There will be some slight compression and expansion of the deformed objects in this mode, depending on how the surfaces are parameterized.
The parameterization of a NURBS surface cylinder is not totally evenly distributed across the arc length of the cylinder so it will not be a suitable tool for doing a high accuracy flow like you want.
However, curve-to-curve flow is done by mapping length traveled along the curve, so it is able to do this kind of work.
So instead of using a plane and cylinder surface, try using line and circle curve objects to do the flow and that may work properly.
9733.4
Thank you Frenchy for the worked solution.
Thank you Michael for the explanation.
The curve-to curve Flow does exactly what I need.
Great!
Mike.
Show messages: All  1  2-4
