Surfaces not tangent or separated
 1  2-21  22-41  42-43
9732.42 In reply to 9732.41
> Of course yes...it was for the concept! :)
Ok, but this discussion thread is about this specific model.
> else does it normal that a volume "subdivided" even with a low subdivision
> can't be filleted ?
It's normal that you can't place an edge fillet along an edge that is already smooth between the 2 surfaces that it belongs to.
That control is not for controlling the amount of subdivision, it's for controlling a weighting effect. In a case like you show there with a value of 6 the surfaces are still smooth where they meet, their curvature is just more tightly bunched into a smaller area. If you zoom in closely on a corner or an edge you should see that it still has a rounded shape there (with a kind of bump and valley), just contained in a much smaller area.
You can only apply fillets to areas of a model that are sharp, not on edges that are already smooth.
Here's what you should see if you zoom in on your object:
9732.43 In reply to 9732.42
Ok that is more clear!
Show messages:  1  2-21  22-41  42-43
