Solid but not solid
All  1-2  3-5
9729.3 In reply to 9729.2
Ah, ok Michael!
To use that command (planar), I've selected the base edge loop (by the way, is there a way to select a loop without select all edges one by one?) and then launch the command... I did'nt undestand that you can use it as "cap planar holes" in a solid!
It's a bi-functional command: it closes the planar holes and it creates planar surfaces from edges! Good.
Thanks a lot
Marco
9729.4 In reply to 9729.3
You have the loop selection
Make a shortcut with this
script:/*Loop selection*/moi.geometryDatabase.selectLoop();
Select 2 edges then call the Shortcut
EDITED: 22 Mar 2020 by PILOU
9729.5 In reply to 9729.4
It works great!
Thanks a lot!!
Show messages: All  1-2  3-5
