Tripod for movements
All  1  2-6
9721.2 In reply to 9721.1
If you disable Grid Snap, Enable Snap Direct, Snap Object
you will obtain a sort of constrain movement!
9721.3 In reply to 9721.2
Thanks Pilou... I've to play with it this evening.
Does it work the same with spline control points?
Thanks a lot
Marco
9721.4 In reply to 9721.3
Of course yes! ;)
9721.5 In reply to 9721.1
Hi Marco, yes make sure you have "Striaght snap" enabled on the bottom toolbar to get movement along one axis.
Then if you move you mouse close to the axis it will snap on to it. You can also hold down Shift to make it engage as well.
9721.6 In reply to 9721.5
Hi Michael, Pilou,
thanks for yor reply.
Yes, I see the behavior of the constrainted moves... It's not bad but I think that a gizmo (or a tripod) might be more useful.
When I can play with it I'll let you know if I'm wrong :-)
Show messages: All  1  2-6
