Hi sunspeed, what happens if you use Edit > Separate on your objects to break them apart from solids into individual surface objects before doing the export, does that help with your import into your CAM software?
Please let me know if that works and if it does I can make an option for doing that automatically.
re: other objects - those are probably hidden objects. If you do a "Save As" instead of "Export", it will write hidden objects to the IGES file but I think they should be marked as "blanked" objects in the file.
