Smooth curve which comes from OBJ import
 1-5  6-25  26-30
9713.6 In reply to 9713.1
Like corchet writes above though, there are some gaps between line segments that are too large for it to be treated as a single polyline though.
If the data was good enough you would use Edit > Join to make it into a polyline, then Rebuild with "Endpoints" mode.
Also another problem with the data is the areas that should be smooth do not have enough refinement, there is about the same angle between different segments as there is for lines within a smooth segment.
With really rough sparse data like that with gaps between pieces there isn't really going to be an automatic process in MoI to handle that.
9713.7
trying another script " points on curve "
you can choose the distance between points ... here 2 examples with 2 and 3 mm
finally the hand drawn ( in yellow ) arcs and small filet give smoother results with various sweeps
EDITED: 28 May 2020 by CORCHET
9713.8
Thanks for your help. Sorry for gaps. It was my bad selection. I`ve uploaded my 3d model from which I took that edge.
I`ve attached image. Left is imported, right is manually created (points are in same places as vertex).
I`ve thought there is some way to convert that polylines to curve line to have points in place of vertices.
If I would convert edges to curves in that way then it should be easy to rebuild subd model in nurbs faster.
I don`t want to rebuild curve. I want to have my line points in place of my vertices. I would like to automate process a bit to not redraw every line from subd mesh.
EDITED: 8 Mar 2020 by MDESIGN
Size: 14.2 KB, Downloaded: 40 times, Dimensions: 425x515px
9713.9 In reply to 9713.8
post the original wings in .obj format
the original obj seems to be build with quads
it could be converted with smooth curves ... maybe ;)
9713.10 In reply to 9713.9
this ?
in ' Draw curve ' choose ' Trough points '
pick the points on your draw ... and all will be made with smooth lines
fantastic tool ! ;)
9713.11 In reply to 9713.10
That`s how I created this (right curve). I used that line tool manually but If I have 1000 lines like this to rebuild whole subd model then it will took ages and I may make mistakes often.
I`m asking about automatic way of doing this on 1000 curves. Next I would rebuild surfaces from those curves in MoI3d.
If 3dm file would be a text file then I could write python script to change that polyline curve to nurbs curve with same vertex->points position.
I know there is scriptingin MoI3d but I don`t know it :)
9713.12 In reply to 9713.10
example with ' through point ' command ( in yellow )
pick points on your sketch or object and the curve is made ... right click to end
go to top view to be sure your curve is flat ... on an object ( if you draw in front view ) you can hasardously pick on points that are not in the same plan
use manipulator around your curve and move a corner ... you'll see the word ' Flat ' when all the points are in the same plan
( not sure my english is orthodox !!! ;)
9713.13 In reply to 9713.11
ok you want ALL the lines to simulate feathers ...
post the original obj .. to experiment Subd
9713.14 In reply to 9713.12
I don`t get it. Where is that command "through points"? There is no such a command in "commands" folder.
9713.15 In reply to 9713.13
Here you have 3 feathers in OBJ (made for subd presentation)
9713.16 In reply to 9713.13
select your object and click 'Subdiv' command
looking for the links
9713.17 In reply to 9713.14
Through points is in Draw curve - Free form
9713.18 In reply to 9713.17
http://moi.maxsm.net/startpos/8
fantastic scripts of Max Smirnov !!
install all the pack 'Subdiv ' ... split scale bridge
and enjoy ;)
9713.19 In reply to 9713.18
Subdiv_beta9
sBridge.v.0.71.2015.03.26
sScale.v.0.6.2015.03.28
sSplit.v.0.95.2015.08.10
unzip and all files in your MoI3d commands folder
you can also install if not Custom UI
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
a bunch of useful stuff and you'll see Subdiv and the others in the bottom bar of MoI
9713.20 In reply to 9713.8
The delCorners script, (of Max), may be helpful.
9713.21 In reply to 9713.15
3 obj subd
internal error when i upload the 3dm file ( size ? ) so i zip the guy ;
9713.22 In reply to 9713.21
yes ... a polyline ... and a click on the script ' Delcorners ' ...
another great tool ;)
And here some infos about modeling inside Moi with the Max Subdive scripts! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
9713.24 In reply to 9713.23
9713.25 In reply to 9713.24
et on croise les doigts pour que, dans une future version de MoI, il y ait genre les outils ' Edit subdivision de Formz ' ou un ' Tspline ' mais en mieux ;)
Show messages:  1-5  6-25  26-30
