Smooth curve which comes from OBJ import
 1-19  20-30
9713.20 In reply to 9713.8
The delCorners script, (of Max), may be helpful.
9713.21 In reply to 9713.15
3 obj subd
internal error when i upload the 3dm file ( size ? ) so i zip the guy ;
EDITED: 28 May 2020 by CORCHET
9713.22 In reply to 9713.21
yes ... a polyline ... and a click on the script ' Delcorners ' ...
another great tool ;)
And here some infos about modeling inside Moi with the Max Subdive scripts! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
9713.24 In reply to 9713.23
9713.25 In reply to 9713.24
et on croise les doigts pour que, dans une future version de MoI, il y ait genre les outils ' Edit subdivision de Formz ' ou un ' Tspline ' mais en mieux ;)
9713.26
Thanks guys, that DelCorners on curves and Subdiv on small patches (between hard edges) is a King!
I`ve created model without extra loops on hard edges (obj). Next in MoI3d I divided it to patches. Next I used subdivide script. In few places I failed but it`s a nice method.
It`s still to long for me but it`s possible to do is nome way.
9713.27 In reply to 9713.26
you can also play with Blend Nsided Loft to generate round surface between curves
place the different curves on Z axes higher or lower ... to various results
( curves are better when you use a script called Rebuild ...( another great tool ) ( need joined segments or curves .... then Rebuild )
9713.28 In reply to 9713.27
If will rebuild nurbs basing on subd meshes I would like to land very close to the original (this is often accepted design and I don`t go too far away from it).
<< Edit subdivision of Formz
Minutes 11.00... FormZ Free is free! ;) So can be a cool companion tool before more subDive native Moi3D Edition functions! ;)
So some tricky but... ;) ( _importObj by Max Smirnov)
EDITED: 8 Mar 2020 by PILOU
9713.30 In reply to 9713.29
mignon ce formz free avec 62 fonctions au lieu de 252 ! ;)
je parlais plutot de ça ... des 13 fonctions manquantes pour de l'edit subdiv plein pot ;)
https://www.youtube.com/watch?v=n0QixFSZppw de 14 minutes à la fin
https://www.youtube.com/watch?v=AGNucQ83__w
et là ça n'est que le b.a.ba
Show messages:  1-19  20-30
