Smooth curve which comes from OBJ import
 1-16  17-30
9713.17 In reply to 9713.14
Through points is in Draw curve - Free form
9713.18 In reply to 9713.17
http://moi.maxsm.net/startpos/8
fantastic scripts of Max Smirnov !!
install all the pack 'Subdiv ' ... split scale bridge
and enjoy ;)
9713.19 In reply to 9713.18
Subdiv_beta9
sBridge.v.0.71.2015.03.26
sScale.v.0.6.2015.03.28
sSplit.v.0.95.2015.08.10
unzip and all files in your MoI3d commands folder
you can also install if not Custom UI
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
a bunch of useful stuff and you'll see Subdiv and the others in the bottom bar of MoI
9713.20 In reply to 9713.8
The delCorners script, (of Max), may be helpful.
9713.21 In reply to 9713.15
3 obj subd
internal error when i upload the 3dm file ( size ? ) so i zip the guy ;
EDITED: 28 May 2020 by CORCHET
9713.22 In reply to 9713.21
yes ... a polyline ... and a click on the script ' Delcorners ' ...
another great tool ;)
And here some infos about modeling inside Moi with the Max Subdive scripts! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
9713.24 In reply to 9713.23
9713.25 In reply to 9713.24
et on croise les doigts pour que, dans une future version de MoI, il y ait genre les outils ' Edit subdivision de Formz ' ou un ' Tspline ' mais en mieux ;)
9713.26
Thanks guys, that DelCorners on curves and Subdiv on small patches (between hard edges) is a King!
I`ve created model without extra loops on hard edges (obj). Next in MoI3d I divided it to patches. Next I used subdivide script. In few places I failed but it`s a nice method.
It`s still to long for me but it`s possible to do is nome way.
9713.27 In reply to 9713.26
you can also play with Blend Nsided Loft to generate round surface between curves
place the different curves on Z axes higher or lower ... to various results
( curves are better when you use a script called Rebuild ...( another great tool ) ( need joined segments or curves .... then Rebuild )
9713.28 In reply to 9713.27
If will rebuild nurbs basing on subd meshes I would like to land very close to the original (this is often accepted design and I don`t go too far away from it).
<< Edit subdivision of Formz
Minutes 11.00... FormZ Free is free! ;) So can be a cool companion tool before more subDive native Moi3D Edition functions! ;)
So some tricky but... ;) ( _importObj by Max Smirnov)
EDITED: 8 Mar 2020 by PILOU
9713.30 In reply to 9713.29
mignon ce formz free avec 62 fonctions au lieu de 252 ! ;)
je parlais plutot de ça ... des 13 fonctions manquantes pour de l'edit subdiv plein pot ;)
https://www.youtube.com/watch?v=n0QixFSZppw de 14 minutes à la fin
https://www.youtube.com/watch?v=AGNucQ83__w
et là ça n'est que le b.a.ba
Show messages:  1-16  17-30
