Smooth curve which comes from OBJ import
 1-10  11-30
9713.11 In reply to 9713.10
That`s how I created this (right curve). I used that line tool manually but If I have 1000 lines like this to rebuild whole subd model then it will took ages and I may make mistakes often.
I`m asking about automatic way of doing this on 1000 curves. Next I would rebuild surfaces from those curves in MoI3d.
If 3dm file would be a text file then I could write python script to change that polyline curve to nurbs curve with same vertex->points position.
I know there is scriptingin MoI3d but I don`t know it :)
9713.12 In reply to 9713.10
example with ' through point ' command ( in yellow )
pick points on your sketch or object and the curve is made ... right click to end
go to top view to be sure your curve is flat ... on an object ( if you draw in front view ) you can hasardously pick on points that are not in the same plan
use manipulator around your curve and move a corner ... you'll see the word ' Flat ' when all the points are in the same plan
( not sure my english is orthodox !!! ;)
EDITED: 28 May 2020 by CORCHET
9713.13 In reply to 9713.11
ok you want ALL the lines to simulate feathers ...
post the original obj .. to experiment Subd
9713.14 In reply to 9713.12
I don`t get it. Where is that command "through points"? There is no such a command in "commands" folder.
9713.15 In reply to 9713.13
Here you have 3 feathers in OBJ (made for subd presentation)
9713.16 In reply to 9713.13
select your object and click 'Subdiv' command
looking for the links
9713.17 In reply to 9713.14
Through points is in Draw curve - Free form
9713.18 In reply to 9713.17
http://moi.maxsm.net/startpos/8
fantastic scripts of Max Smirnov !!
install all the pack 'Subdiv ' ... split scale bridge
and enjoy ;)
9713.19 In reply to 9713.18
Subdiv_beta9
sBridge.v.0.71.2015.03.26
sScale.v.0.6.2015.03.28
sSplit.v.0.95.2015.08.10
unzip and all files in your MoI3d commands folder
you can also install if not Custom UI
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
a bunch of useful stuff and you'll see Subdiv and the others in the bottom bar of MoI
9713.20 In reply to 9713.8
The delCorners script, (of Max), may be helpful.
9713.21 In reply to 9713.15
3 obj subd
internal error when i upload the 3dm file ( size ? ) so i zip the guy ;
9713.22 In reply to 9713.21
yes ... a polyline ... and a click on the script ' Delcorners ' ...
another great tool ;)
And here some infos about modeling inside Moi with the Max Subdive scripts! ;)
https://moi3d.com/forum/index.php?webtag=MOI&msg=9689.1
9713.24 In reply to 9713.23
9713.25 In reply to 9713.24
et on croise les doigts pour que, dans une future version de MoI, il y ait genre les outils ' Edit subdivision de Formz ' ou un ' Tspline ' mais en mieux ;)
9713.26
Thanks guys, that DelCorners on curves and Subdiv on small patches (between hard edges) is a King!
I`ve created model without extra loops on hard edges (obj). Next in MoI3d I divided it to patches. Next I used subdivide script. In few places I failed but it`s a nice method.
It`s still to long for me but it`s possible to do is nome way.
9713.27 In reply to 9713.26
you can also play with Blend Nsided Loft to generate round surface between curves
place the different curves on Z axes higher or lower ... to various results
( curves are better when you use a script called Rebuild ...( another great tool ) ( need joined segments or curves .... then Rebuild )
9713.28 In reply to 9713.27
If will rebuild nurbs basing on subd meshes I would like to land very close to the original (this is often accepted design and I don`t go too far away from it).
<< Edit subdivision of Formz
Minutes 11.00... FormZ Free is free! ;) So can be a cool companion tool before more subDive native Moi3D Edition functions! ;)
So some tricky but... ;) ( _importObj by Max Smirnov)
EDITED: 8 Mar 2020 by PILOU
9713.30 In reply to 9713.29
mignon ce formz free avec 62 fonctions au lieu de 252 ! ;)
je parlais plutot de ça ... des 13 fonctions manquantes pour de l'edit subdiv plein pot ;)
https://www.youtube.com/watch?v=n0QixFSZppw de 14 minutes à la fin
https://www.youtube.com/watch?v=AGNucQ83__w
et là ça n'est que le b.a.ba
Show messages:  1-10  11-30
