Rotate Array?
All  1-19  20
9710.20 In reply to 9710.19
Hi MindSet,
> I need to be able to run RotateArray more than once upon the same array, so that I
> can do so from more than one viewport.
The result generated by RotateArray can be used in a 2nd run just by running the command again.
Just move your mouse over the other viewport that you want to use for the second application.
Make sure to include a point object with the array, that will be used as the center of rotation.
So for example here's an array prepared for RotateArray:
Select the arrayed objects:
Run RotateArray:
Move mouse over the other viewport, for example here I moved over the "Front" viewport:
Run RotateArray again, this one will rotate in the Front view:
Show messages: All  1-19  20
