Command Line parameters and debug console with Mac OS MoI v4 beta Jan-22-2020
All  1  2-4
9690.2 In reply to 9690.1
Hi goetzmoritz, the moi.command.getCommandLineParams() gets the command line parameters of the currently running MoI command, not the parameters given to MoI.exe .
Commands can be run with parameters given to them, like "Open filename.3dm" for example, and moi.command.getCommandLineParams() is used by commands that can accept parameters to find out what they are.
You can instead use (in MoI v4) moi.getExecutableCommandLineArgs() to get the ones given to MoI.exe when it was launched. It returns a list of strings.
9690.3 In reply to 9690.2
thank you, that worked.
Great piece of software you've created there!
Now, what about the debug console? Is there any way to access that on macos besides that hacky way to paste it into a alert window?
9690.4 In reply to 9690.3
Hi goetzmoritz, I'm glad that worked! You can show the debug log on Mac by setting up a shortcut key and putting this on it:
script: moi.ui.createDialog( 'ShowLog.htm' );
Show messages: All  1  2-4
