About SubDivide in nurbs :)
 1-4  …  45-64  65-84  85-104  105-122
Funny in few seconds...
Else how is not evident (here in Blender but will be the same in other) to make in the rules of art
a submodeling sculpting! :)
9689.86 In reply to 9689.1
Dear Pilou,
Many thanks for all the tips on SubD modelling and especially for the introduction to SimLabs Composer. The possibilities are endless.
Kind regards,
Philip
LineWeb for help to make Box Modeling :)
Draw curves
Rebuild say 10 points
Line Web: Lines or polylines or curves: 10 points (order of selection is important! )
Kill curves
Loft "Lines"
Kill Lines
Select faces : Extrude with "Keep Separate"
Boolean Union
Subdivide
EDITED: 21 Jan 2022 by PILOU
And if you save your object in OBJ
You can use the free funny Spline for some cool things in seconds without some efforts! :)
Click on the little object ;)
And of course Zoom, Rotate, Move...
9689.89 In reply to 9689.88
Respect Pilou for your creative use of MOI !
You always amaze us with new surprises !
Not exactly Sudivide but...
General article bout "NGons" https://www.artstation.com/artwork/0n93EV
9689.91
Hello all,
Where can I find Subdiv_classic (not Subdiv_Beta_9).
9689.92 In reply to 9689.91
on this page ! ;)
In case of problem in high resolution, simply increase the Size drastically like 5000%!
https://moiscript.weebly.com/subdivision.html Sub_Dic Classic : Catmull-Clark algorithm
9689.93 In reply to 9689.92
it says "There was a problem downloading this attachment. Please try again later."
http://moi3d.com/forum/get_attachment.php?webtag=MOI&hash=d663bac37f6f11f9b09b78314c160289&filename=SubdivClassic.v.0.6.2015.02.22.zip
9689.94 In reply to 9689.93
Hi Psygorn, I don't know why but Max removed all the scripts that were set as file attachments here in the forum, and his script archive web site is offline as well.
So they are not available at their previous locations.
9689.95 In reply to 9689.94
Thank you for your reply,
I kind of expected that (Knowing Max's website is offline) However, I am having hope that someone has it and could share it with me.
_Psygorn
9689.96 In reply to 9689.91
Here is a copy
9689.97 In reply to 9689.96
Hi Wayne hill,
Thank you :-)
9689.98 In reply to 9689.97
Most of that stuff can be found in the commands/scripts archive i posted.
Mostly what i left out of that collection were UI related customizations.
9689.99 In reply to 9689.94
""""I don't know why but Max removed all the scripts that were set as file attachments here in the forum""""""
That probably falls under "ran out of room"...
I had to do that a couple years ago too...
<< I don't know why...
I believe that war is maybe a dramatic reason! :(
Page updated! ;) (with the "classic" one that was installed in my Moi previous version ! :)
EDITED: 18 Apr 2022 by PILOU
9689.101
Hello guys,
Could you please explain to me How I can properly use this Creat under SubD tab? Why it seems as if it works in strange ways?
Explanation: I have models made by Blender (Obj files) when I import them into Moi using the Create button I showed. it seems that they are converted to NURBS and scaled-down! but when I perform SubD on an imported Obj file (using ImpObj) and export it as an Obj from Moi and then import it again using Create button under the SubD tab it seems it does nothing!
Edit: I think I figured it by now! if the Weld vertex box is not checked during the exportation process then "Create button" only imports an object and it doesn't turn it into NURBS.
EDITED: 18 Apr 2022 by DRILLBIT
9689.102 In reply to 9689.101
HI Psygorn,
It's meant to convert a polygon mesh file that has been structured for sub-d smoothing.
If you get strange results it probably means the model you are trying to convert has not been modeled as a sub-d control cage.
You should see the same strange results if you imported the same file into a poly modeling program and then applied sub-d smoothing on it.
9689.103 In reply to 9689.101
Your OBJ file from Blender must be "Quadrangulated" for best result in SubD!
9689.104 In reply to 9689.103
Thanks PILOU :-)
Show messages:  1-4  …  25-44  45-64  65-84  85-104  105-122
