About SubDivide in nurbs :)
 1-9  …  30-49  50-69  70-89  90-109  110-122
Flow function can be practical for SUbDIve!
Here a cube was projected on a Sphere...of course as always imagination must be large for predict the result!
The cutting line method shown above is significantly slower than cutting from a segment!
But indispensable if you want an oblique cut!
Some minutes of the days :)
Precision! :)
9689.74 In reply to 9689.73
You need Max's plugins for this to work correct?
9689.75 In reply to 9689.74
Yes of course: in this precise case _sBridge by Max Smirnov
http://moi3d.com/forum/index.php?webtag=MOI&msg=6674.254
who can be also used of course for other thing than Subdivision!
Seems last version of Rhino 7 uses intensively the SUbD Method! :)
Moi SUbdivided object + texture of the fabulous free Vervette SandBox online
http://www.taron.de/Vervette/sandbox/
EDITED: 21 Feb 2021 by PILOU
Searching something for all kill the internal volume (faces, edges) for make some cool subdivided object...
it appears that is very difficult directly in Moi ! (for the moment (?) )...
Boolean union will remove the internal faces but also merge together some of the outer ones.
Edit Join don't remove internal faces!
So no success!
5 boxes for test your scripts or other tricks! https://moiscript.weebly.com/uploads/3/9/3/8/3938813/5boxes.3dm
the 3 little boxes have no internal faces because built with Max sSplit :)
the 2 other have mutual faces!
But i have found some little tricks! :)
- Export as OBJ / Ngon Without Without Weld vertices along Edges!
- Import OBJ from SUbDiv/ Create /From File
- Boolean Union
- Max Subdiv
That works fine...except for this case!
don't works when "cubes" are tangent by a commune vertical edges!
Works in other compact or alone positions!
the bad case (works in other cases! )
so no total success again!...
but i have found another trick for this particular case! :)
Up or down the top face of one of these 2 boxes by a very, very tiny distance!
et voilà! :)
Have fun subD modeling before a script or command OR NODES who kill all internal volume! :)
(second box was made with sBridge by Max Smirnov
Relaxing in 10 seconds :)
Bonus :)
EDITED: 18 Jun 2021 by PILOU
PolyLine
Offset
A segment between same vertex of the 2 PolyLines
Sweep
CopyMove Joined Surfaces
Separate
Extrude
Boolean Union
SubDive
EDITED: 7 Jul 2021 by PILOU
9689.83 In reply to 9689.82
Cool techniques, Pilou!
─ Metin
visualizer • illustrator • 3D designer — metinseven.nl
When some faces on a solid are not divided for general SubDivide so fails
Draw lines missing
Select All / Trim
Kill Curves (Browser curves selection)
SubDivide
EDITED: 23 Sep 2021 by PILOU
Funny in few seconds...
Else how is not evident (here in Blender but will be the same in other) to make in the rules of art
a submodeling sculpting! :)
9689.86 In reply to 9689.1
Dear Pilou,
Many thanks for all the tips on SubD modelling and especially for the introduction to SimLabs Composer. The possibilities are endless.
Kind regards,
Philip
LineWeb for help to make Box Modeling :)
Draw curves
Rebuild say 10 points
Line Web: Lines or polylines or curves: 10 points (order of selection is important! )
Kill curves
Loft "Lines"
Kill Lines
Select faces : Extrude with "Keep Separate"
Boolean Union
Subdivide
EDITED: 21 Jan 2022 by PILOU
And if you save your object in OBJ
You can use the free funny Spline for some cool things in seconds without some efforts! :)
Click on the little object ;)
And of course Zoom, Rotate, Move...
9689.89 In reply to 9689.88
Respect Pilou for your creative use of MOI !
You always amaze us with new surprises !
Show messages:  1-9  10-29  30-49  50-69  70-89  90-109  110-122
