About SubDivide in nurbs :)
 1-20  21-40  41-60  61-80  81-100  …  121-122
Select a Face Select All Psplit
Select each face
Extrude
Subdivide
If a shell had no problem you can make multiple Subdivisions for refine the volume!
For "crease" a face with the classic "Polygonal" method...
else playing with the Sscale...
9689.45 In reply to 9689.39
are you splitting the faces manual ?
Barry
9689.46 In reply to 9689.45
Oh no! You have the magic function Ssplit with selection of one(s) face(s) (your image above)
Of course make a shortcut for a speedy race ;)
mine are P = SsPlit, E = Extrude, K = Subdivide, S = Sscale , B = Bridge
With only that you can make miracles! :) (I can't memorize more! :)
Here only 2 faces in the same time!
Like here all faces are splitted in the same time!
But you must select one face first then all the rest with for example the rectangle selection!
By hands will be a nightmare : drawings lines, Triming, etc...
or only one edge for "SPlit" all the volume!
Here split edge one by one (very cool to make a right Click for recall the function after a new edge selection! ;)
EDITED: 10 Mar 2020 by PILOU
9689.47 In reply to 9689.46
having selected 2 faces on a cube and then running the sSplit command I get this.
Sorted have download the sSplit script from Max's website and replaced the one in my command folder and now working fine.
Barry
EDITED: 10 Mar 2020 by BARRY-H
Always amazed as little forms can do in no time! :)
Add a dummy SPlit at the lateral sides to make extrusions (the fork tines).
Make extrusions on perimeters! So kill inbetwenner faces !
Separate/Join when a subdivision is made!
Close a hole with successive snaped extrusions!
(here one by one because intervals are not the same! So no possibility to use array! )
You will have a solid at the end!
Of course not yet so fluid than Rhino 7 but funny! :)
EDITED: 11 Mar 2020 by PILOU
Extrude by Dir then
Orient / Line-Line / Stretch / Copy can be cool + Plane sides
can be cool for increase the volume on no regular perimeter!
Infinite possibilities of Bridge function! :)
If any questions about this funny method of subdivision inside Nurbs don't hesitate!
Thx Max Smirnov for these magic tools!
Advantage is the very few tools to learn/use! :)
- Extrude face(s) (not on the extremities)
- Scale with Points enabled
- Split on a single Edge or a face(s)... don't need to recall it, just Right Click
- Bridge only between 2 faces : careful of overlapings
( useful for replace the Extrude at the "extremities" : just Copy / Move the face then Bridge )
Show Points from the beginning, and never accept the SubDive before the final result wanted... :)
Here just a tranparent Texture of the Engine Render...
EDITED: 12 Mar 2020 by PILOU
9689.53 In reply to 9689.52
Many thanks Pilou for your fantastic inspirations....great work !!!
But would you like to post some kind of "how to basic tutorial - as a step by step cook-book" for all the un-initiated noobs ?
That would realy by a mind-opener ??? Big thanks + good luck to you
Best wishes
O.
9689.54 In reply to 9689.53
In fact that is very simple! :)
The volume must be without internal faces!!!
This follow is the general case who always works! The Bridge function between 2 separated faces!
In this specific case the Extrude will also works because faces are not on the "extremities"
and not touch between them !
Box on the left don't work because Top/ Bottom face are too complex for the Plugin!
You must split it first! With any method but without internal faces! Here there is a new building :)
Use of the SsPlit function is of course used!
Here following Subdivision after Extrude will not work!
Because there are no more "triming faces"!
9689.55
Hey Sub-D Master Pilou, thank you so much for sharing your insights !!
In case of 2 neighbour (or more) different faces - Will works with the volume's faces extremities! ;)
A possible method (the funny game is to find the more speedy effective one! ;)
- Select & Copy Move the 2 faces
- Delete original (easy because yet selected)
- Select Perimeter (careful to not select the vertical middle edge(s) !!! )
- Extrude WITHOUT Cap Ends!!!
- Join All
- SubDivide
Of course can be multiple if you take the same length of Extrude! ;)
(there is an optic effect of record, extrude goes from faces to piece as post above)
And Move Points is always possible!
And of course the Sscale!
Just use 2 Steps of subdivision (first plane - Extrusion) then extrude the faces!
I am always amazed by the voluptuous result in no time! :)
About history after a Mirror : seems Move & Sscale work ! (object or points)
Psplit, Extrude of face(s), Bridge of 2 faces of Original don't work for the moment!
For make an history of a mirrored object
- Mirror Object Original
- Select mirrored Object
- History Enable Update
- Modify Original! :)
EDITED: 15 Mar 2020 by PILOU
Multiply an object by Array for unic pasted volume
- Just kill the 2 "faces jonction extremities"
- Use Array
- Recreate the 2 "faces jonction extremities" of the complete object
- Join All
- SubDivide
Show messages:  1-20  21-40  41-60  61-80  81-100  101-120  121-122
