Viewport causing an app hang
 1  2-21  22-23
9688.2 In reply to 9688.1
HI LocusDio, it's likely to be a video driver bug. Probably the first thing to try is to see if there is any newer driver available, check directly at the Nvidia web site, not through Windows Update.
If there isn't then another thing that might help would be to try rolling back your video driver, see if there is an option as described here:
https://www.nvidia.com/en-us/drivers/driver-rollback/
and also here:
https://www.tenforums.com/tutorials/60478-roll-back-driver-previous-version-windows-10-a.html
Another thing you can try is in MoI go to Options > General and push the "Edit .ini file" button. Inside moi.ini find the line inside the [View] section that says DisplayThreadLimit= and set it to DisplayThreadLimit=1 .
Do any of those things make any difference?
9688.3 In reply to 9688.2
Thanks for getting back to me so quickly, Michael. I do appreciate it.
Unfortunately I tried every one of those steps and the problem persists.
I first tried setting the DisplayThreadLimit to 1 before rolling back, unfortunately it was of no use both before, and after the rollback.
Let me know if there's anything else I can do to help resolve my issue.
9688.4 In reply to 9688.3
Hi LocusDio, the only other thing I can think of is to try an older video driver, I think you can get older ones from here:
https://www.nvidia.com/Download/Find.aspx?lang=en-us
Hopefully a new video driver will be out soon that will fix this for you. You are the only person who has reported this problem so far.
EDITED: 15 Feb 2020 by MICHAEL GIBSON
9688.5 In reply to 9688.4
I'll give that a shot.
Thanks for the help, Michael. Hopefully I can get this issue fixed.
9688.6 In reply to 9688.5
Hey Locus,
You could give a "perform a clean install" tickbox a shot, it's an option during nvidia driver installation.
Also, you could eventually try this:
https://www.guru3d.com/files-details/display-driver-uninstaller-download.html
before trying out a new version.
If you are experiencing weird behavior in other apps, it could be heat or psu power cap/quality related.
Good luck!
9688.7 In reply to 9688.6
Ah, thanks nameless. Much appreciated.
I'll give those things a shot, and keep an eye out for my hardware.
9688.8 In reply to 9688.7
Hi LocusDio, one other thing is if your computer has accumulated a lot of dust in it clean that out since that can contribute to overheating.
But yes if that was it rather than a driver problem I would expect you'd see it in other apps too.
9688.9 In reply to 9688.8
That's an amazing rig by the way, didn't catch it the first time.
Just curious, what is your power supply for this?
9688.10 In reply to 9688.9
oh, thanks nameless.
I have an EVGA Supernova 1600 T2 80+ Titanium. Rated for 1600W.
9688.11 In reply to 9688.10
boom! There goes my power concern :)) Yeah, let us know if you figure out what's causing your weird moi behaviour!
9688.12
I figured I'd update you guys on my situation.
I've tried all the methods and avenues that have been mentioned here, even rolling back to a driver released in November when I know I didn't have issues operating MoI, and unfortunately my problem still persists.
Like I mentioned in my original post, this problem is only happening in MoI, all the other software I use have no issues with my graphics card what-so-ever.
I don't know if this merits an even further investigation, but I'm struggling to operate MoI because of this problem. Hopefully it will get resolved but it's starting to look like I'm going to have to explore other software avenues if this keeps up any longer.
I really don't want to give up on MoI, I absolutely love this software, but it's been rendered absolutely unusable because of this issue.
Thanks again for your guys' help and suggestions.
9688.13 In reply to 9688.12
Hi LocusDio, thanks for the update and sorry MoI isn't working for you properly.
Unfortunately right now it's doubtful that I'll be able to find a solution, maybe if someone else reports the same issue it will help to identify a pattern and find the root cause. So far though you are the only person to have seen this problem.
Sorry for the difficulty,
9688.14 In reply to 9688.12
Actually one more idea just occurred to me, did you possibly install any kind of anti-virus or anti-malware packages during this recent time period when the trouble started?
9688.15 In reply to 9688.14
No worries Michael, I completely understand your situation. I just wish I was better versed in reconciling these kinds of issues.
As far as the anti-virus situation goes, I haven't installed any new anti-virus/malware packages at all.
Thinking about going as far as a reinstall of windows on my end, but that's probably unnecessary.
I'll try to keep you posted on things I've tried as I come up with more ideas. Thanks again for all your help.
Message 9688.16 deleted 19 Feb 2020 by BEMFARMER
9688.17 In reply to 9688.15
Hey LocusDio,
Just throwing a long shot, does your motherboard have any onboard graphics options and do you see anything like that in device manager in display adapters? I just thought it could be worth checking out, there is an option via the nvidia panel to choose a gpu for each application and if there were other gfx devices in your system MoI could be using a weird one.
Also, it could be worth checking out if uninstalling gpu drivers completely and letting windows run on the default display adapter driver for your card solves the issue. Or even booting into safe mode and see if MoI crashes or not.
Again, just things that popped into my head and I would try in your shoes, I do not mean to make you pointlessly jump through hoops to make MoI work.
Good luck! :|
9688.18 In reply to 9688.17
Ah thanks for the suggestions, Nameless!
Unfortunately, I had the foresight to test exactly that in between uninstalling my drivers via the method you described a few days ago. It unfortunately was still freezing in Safe mode, without nvidia's graphics drivers installed.
I do believe that effectively rules out it being a display driver issue. I'll give it a 2nd test, though. I guess it couldn't hurt.
I don't have an onboard graphic's chip, either; my Motherboard is an Asus Rog Zenith Extreme Alpha X399. Onboard graphics were one of the bells and or whistles it didn't come equipped with.
9688.19 In reply to 9688.18
Hi locus,
Does your issue happen on just a default "empty" file, or are you dealing with a specific file?
If it is file specific, tune the view angle to something like 40, then test.
Sorry, that's all i have...
9688.20 In reply to 9688.19
Side note:
Nice build! Putting together something for my son right now. I went intel. Just waiting for the processor to become available and i'll get it completed.
9688.21 In reply to 9688.20
Thanks for the advice, BurrMan. Appreciate it.
It happens in an empty file, and whenever I load a file up as well.
I'm not sure I'd want to change the perspective, it would just negatively impact my design work in all honesty. Though it's worth a test to see if it makes any difference in the viewport problem.
Appreciate the compliments about the rig as well. Good luck with your son's! hopefully it all turns out well!
Show messages:  1  2-21  22-23
