Custom UI for PC vs Mac
All  1-2  3-4
9683.3 In reply to 9683.2
That worked great. Thank you!
Everything seems to be working with the custom toolbar except the "LightingOptions.htm" file in the Command folder is not showing any of the "MajikPrimer" lighting options in the LightingPresets button in the toolbar. The buttons says "Lighting Options add-on not found".
I also noticed if I change the file name of the Start Up tools...the tools are still visible on the toolbar. I was looking to see how to turn on/off the visibility of some of the toolbar buttons I'm not using, other than deleting the file itself.
Thx!
M
9683.4 In reply to 9683.3
Hi mat, you're welcome!
I think that one depends on lighting settings having been saved in your moi.ini file by this other plugin:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.29
If you copy over your moi.ini file that will probably make it work.
I'd recommend making a sibling folder to startup, something like "startup_bak" for example. If you want to disable a startup file, move it over to that other folder and if you want to re-enable it, move it back to regular startup.
Show messages: All  1-2  3-4
