Looking for a script that would delete all of the inside lines after trimming
All  1-2  3-4
9682.3 In reply to 9682.1
It's Boolean Union! ;)
so Make a shortcut with BooleanUnion in the second column
or Press Tab and write BooleanUnion
with any capitals or not but without space! (so BoolEanUNIOn, BOOleanUnion, booleanunion ...etc are valid)
If you want a comment in your ShortCut
script: /* Boolean Union for simulate Trim lines & Join */ script:moi.command.execCommand( 'BooleanUnion' );
(sorry i have not seen the Michael post! But now you have a little more info! :)
EDITED: 12 Feb 2020 by PILOU
The image you gave is not a trimming result but a boolean/union, it seems.
Trimming cut the curves and you have to give which pieces have to be removed and then you have only pieces.
Your edges are connected into a curves on your result ?
If yes, you want a union.
If you want non connected pieces, same but you add in a script boolean union + a separate action
(Same... We all respond same time...)
Show messages: All  1-2  3-4
