Trouble on OSX
All  1-2  3-4
9681.3 In reply to 9681.2
HI Michael,
I did download the trial version available on the website and I place the file on the applications folder. Unfortunately, the software doesn't starts. I have Mojave and I am seriously thinking to buy it as I have read that Moi works perfect to convert files from Rhino to C4D but I really would like to check first.
Is this version compatible with Mojave? is there any specific instruction to install the software that you could advise?
Felipe
9681.4 In reply to 9681.3
Hi Felipe, yes the version 3.2 trial is compatible with Mojave.
What happens exactly when you try to run it, is there an error message?
If it says it won't run because it's from an "unidentified developer", that's what the OS says when you try to run an app that is not digitally signed. When you encounter that you need to right-click on the app and choose "Open" from the menu. That will put the app on a white list and it will open normally after that.
If it's some other problem than that if you can please show some more detail about what happens I might be able to figure out what's going on.
Show messages: All  1-2  3-4
