Shortcut and Scripts Support
All  1  2-3
9680.2 In reply to 9680.1
Hi tsiwt, the philosophy for MoI's shortcuts system is that the shortcuts are a personalization function that you can tune to your own preferences.
There is not an emphasis on having an extensive default set of shortcuts. Actually more the opposite of that - the original concept for MoI was that it could be used easily on a tablet without needing to touch the keyboard at all.
But if you want to have a bunch of predefined shortcuts that someone else has designed for you, there are some available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=8123.1
The above thread can be found by doing a forum search for "shortcuts" targeting titles only.
Also the tutorial from Arrimus3D includes a shortcut key setup I think, there is a link to that at http://moi3d.com/resources.
9680.3
Hi tsiwt,
Only my two cents here, but if you already have "muscle memory" of shortcuts on a different 3d app, I would capitalize on that, building MoI shortcuts around the same logic. It's easier to keep key bindings in your mind that way, even if you go away from the program for some time.
Welcome!
Show messages: All  1  2-3
