Protect style from unhide all
All  1-4  5-10
9677.5
I also had this problem. Very useful!
Is it possible to make this script to hide stuff when somthing is selected? this way I can replace it with the default Hide/Unhide command.
Thanks!
9677.6 In reply to 9677.5
Hi Stargazer,
Try this:
script: if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { moi.geometryDatabase.hide(); } else { var index = -1; var style = moi.geometryDatabase.findStyle( 'Archive' ); if ( style ) index = style.index; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.hidden && obj.styleIndex != index ) { obj.hidden = false; obj.getSubObjects().setProperty( 'hidden', false ); obj.selected = true; } } }
9677.7
Thank you so much!!
9677.8
Great Script - where are the default styles kept so I can add the ARCHIVE style in?
9677.9 In reply to 9677.8
Hi Alex, you can alter the default styles by setting up styles how you want in a .3dm file and then specifying that .3dm file as the startup template under Options > General > Template file.
9677.10
thanks again Michael
Show messages: All  1-4  5-10
