Protect style from unhide all
All  1  2-10
9677.2 In reply to 9677.1
Hi Andre, re:
> It would be nice if there was a checkbox in the "Edit style" dialog like "Protect from 'Unhide all'" which,
> when enabled, causes this particular style not to be unhidden when I unhide all objects.
I can see how that would be useful, but the general thing that I don't like about these kinds of special override modes is it can lead to great confusion when someone else is trying to look at your file.
How about a script that you could set up on a shortcut key that will do a "Show all except Style=Archive" when you push the shortcut key, would that help?
If so give this one a try:
script: /* Show all except Style=Archive */ var index = -1; var style = moi.geometryDatabase.findStyle( 'Archive' ); if ( style ) index = style.index; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.hidden && obj.styleIndex != index ) { obj.hidden = false; obj.getSubObjects().setProperty( 'hidden', false ); obj.selected = true; } }
9677.3
That works nicely. :)
I have even added it to SidePane.htm:
<td><moi:CommandButton icon="icons/UnHideIcon.png" onclick="/* Show all except Style=Archive */ var index = -1; var style = moi.geometryDatabase.findStyle( 'Archive' ); if ( style ) index = style.index; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.hidden && obj.styleIndex != index ) { obj.hidden = false; obj.getSubObjects().setProperty( 'hidden', false ); obj.selected = true; } }">Unhide all<br>except Archive</moi:CommandButton></td>
Size: 6.1 KB, Downloaded: 24 times, Dimensions: 64x64px
9677.4 In reply to 9677.3
Hello Andre,
my favorite script for managing this:
http://kyticka.webzdarma.cz/3d/moi/#HideSwap
have a nice day
Karsten
9677.5
I also had this problem. Very useful!
Is it possible to make this script to hide stuff when somthing is selected? this way I can replace it with the default Hide/Unhide command.
Thanks!
9677.6 In reply to 9677.5
Hi Stargazer,
Try this:
script: if ( moi.geometryDatabase.getSelectedObjects().length > 0 ) { moi.geometryDatabase.hide(); } else { var index = -1; var style = moi.geometryDatabase.findStyle( 'Archive' ); if ( style ) index = style.index; var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.hidden && obj.styleIndex != index ) { obj.hidden = false; obj.getSubObjects().setProperty( 'hidden', false ); obj.selected = true; } } }
9677.7
Thank you so much!!
9677.8
Great Script - where are the default styles kept so I can add the ARCHIVE style in?
9677.9 In reply to 9677.8
Hi Alex, you can alter the default styles by setting up styles how you want in a .3dm file and then specifying that .3dm file as the startup template under Options > General > Template file.
9677.10
thanks again Michael
Show messages: All  1  2-10
