Color Gradient script?
 1-13  …  34-53  54-73  74-92
Always fun :) And thx to Max Smirnov for its incredible Subdivision, Split, Bridge, Scale !
Explode Move an Hidden Function By Michael
EDITED: 15 Feb 2020 by PILOU
9676.75 In reply to 9676.71
> @ Michael : Just a little detail :)
> with the new 360 option you must erase this internal rectangle in the English "360" original! ;)
Oops, looks like I forgot to remove that on the Path one. I've updated the attachment at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9676.67
Thanks, - Michael
9676.76 In reply to 9676.74
Looking delicious Pilou :) <3
What is the Hidden Function script?
9676.77 In reply to 9676.76
The hidden function is "ExplodeMove" native you must Press Tab and write it (with any capitals (so EXplodeMOVe is valid) but without Spaces! ;)
You can also make a shortCut
And it's present also if you have installted the List Scripts/Commands helper...for me the more speedy trick! ;)
ExplodeMove is in Max's CustomUI, at the top of his Scripts menu.
9676.79
Is there some way that a version of the Color Gradient script could apply its effect to the vertices of a obj export (file)?
9676.80 In reply to 9676.79
Hi Mindset,
Sorry no there isn't any way to set them individually, faces in .obj export will inherit the color of the surfaces they were generated from.
To manipulate individual mesh vertices you would need to do that in a polygon mesh editing program.
9676.81
Hi.
Please tell me how to assign hotkeys for the following actions:
1. Assign a fixed color to selected curves?
2. Assign a fixed color to all curves?
The color will be assigned in advance in the script:
"var red = XX, green = XX, blue = XX"
For version 3.0
All gradient scripts are very cool, but sometimes I need to quickly assign a color with hotkeys to individual curves or all curves.
I understand that the script will be like this:
"script: / * Assign styles to solids * / var styles = moi.geometryDatabase.getObjectStyles (); var breps = moi.geometryDatabase.getObjects (). getBReps (); var style_index = 0; for (var i = 0; i <breps.length; ++ i, ++ style_index) {if (style_index == styles.length) {style_index = 0;} var brep = breps.item (i); brep.styleIndex = style_index;} "
only for a single color and only for curves.
tried to edit this script, but I lack knowledge of syntax)
9676.82 In reply to 9676.81
Michael provided code for changing styles, used in the script for Jacobian function graph script, a few years ago. Do not know if you already have all of the code.
-Brian
By Michael
script: /* Gradient Styles */ var red = 12, green = 15, blue = 20; for ( var i = 1; i <= 100; ++i ) { var style = moi.geometryDatabase.addStyle(); style.name = 'Gradient ' + i; style.color = (Math.abs(red%256)<<16) | (Math.abs(green%256)<<8) | Math.abs(blue%256); red += 2; green += 3; blue -= 7; }
Message 9676.84 deleted 19 Dec 2020 by BEMFARMER
9676.85
I probably explain it wrong)
I need a simple script.
Just a fixed color. Color predefined in the script.
I understand color definition like this: red = XX, green = XX, blue = XX
1. all curves is assigned a color red = XX, green = XX, blue = XX (one fixed color)
2. the selected curves are assigned a color red = XX, green = XX, blue = XX (one fixed color)
only in MOI v.3 language for MOI to understand :)
9676.86 In reply to 9676.85
Hi GonzoRus,
I think that the desired colors need to exist in the Styles menu???
An existing script is:
script: /*!Assign styles to curves */ var styles = moi.geometryDatabase.getObjectStyles(); var curves = moi.geometryDatabase.getObjects().getCurves(); var style_index = 0; for ( var i = 0; i < curves.length; ++i, ++style_index ) { if ( style_index == styles.length ) { style_index = 0; } var curve = curves.item(i); curve.styleIndex = style_index; }
By a minor edit to this existing script, try out the following experimental script.
(I changed color from Black to Red, and deleted incrementing ++style index.)
TRY
script: /*!Assign RED style to ALL curves */ var styles = moi.geometryDatabase.getObjectStyles(); var curves = moi.geometryDatabase.getObjects().getCurves(); var style_index = 1; for ( var i = 0; i < curves.length; ++i ) { var curve = curves.item(i); curve.styleIndex = style_index; }
I'll leave any more up to the experts.
EDITED: 19 Dec 2020 by BEMFARMER
9676.87
This script does not work quite correctly. It makes ALL curves the same specified color (color 0, 1, 2, 3, etc.) existing in the Style Menu. BUT. "Undo" and "Redo" stop working for styles.
This script does not work correctly, it assigns different colors to the curves)
9676.88 In reply to 9676.87
Hi GonzoRus,
I concur with you. The same failure to "save" to history occurs in both MoI3 and MoI4beta.
Pushing enable history seemed to make no difference.
A test with multiple color changes, MoI3 or MoI4beta:
Create a few Black curves, and save .3dm.
Change the color of the curves to Green, using Style menu.
Change the color of the curves to Purple, using Style menu.
Change the color of the curves to Magenta, using Style menu.
Change the color of the curves to Red, with the RED script, OR to multi-colors, with the "multi-color" script.
Change the color of the curves to white, using Style menu.
Undo History is not saving the RED colored curves, but History is saving all of the other colored curves, as per multiple pressing of undo.
Similar for Redo History.
The same applies to the script which applies "rainbow" colors to solids.
I would call it normal behavior, but not the desired behavior?
Is there some way to enable history for these color scripts?
9676.89 In reply to 9676.87
Hi GonzoRus,
> for styles.
Please give these versions a try:
/* Assign selected curves to style = Red */ var starting_selection = moi.geometryDatabase.getSelectedObjects(); var curves = starting_selection.getCurves(); moi.geometryDatabase.deselectAll(); curves.setProperty( 'selected', true ); var style = moi.geometryDatabase.findStyle( 'Red', false /*Create if not found*/ ); if ( style ) { moi.ui.propertiesPanel.editStyleIndex( style.index ); } moi.geometryDatabase.deselectAll(); starting_selection.setProperty( 'selected', true );
/* Assign all curves to style = Red */ var starting_selection = moi.geometryDatabase.getSelectedObjects(); var curves = moi.geometryDatabase.getObjects().getCurves(); moi.geometryDatabase.deselectAll(); curves.setProperty( 'selected', true ); var style = moi.geometryDatabase.findStyle( 'Red', false /*Create if not found*/ ); if ( style ) { moi.ui.propertiesPanel.editStyleIndex( style.index ); } moi.geometryDatabase.deselectAll(); starting_selection.setProperty( 'selected', true );
These use the properties panel mechanism for applying the style index, it's what is used when you assign a style by clicking on the style name in the properties panel and it does the extra work to set up an undo unit to make it work with undo. The properties panel only modifies the current selection so for the version that does all curves it modifies the selection first and then restores it afterwards.
9676.90
Thanks Michael!
Everything works great with your scripts.
Undo and Redo work great. Thank you!)
9676.91 In reply to 9676.89
Both shortcuts work!
A minor observation:
For customUI shortcuts "gearpair" icon menu, add the ! i.e. /*!
Also, the second comment /*Create if not found*/ causes the customUI gearpair icon to display all of the code up to the last */, which is a long line of text in the menu.
so I removed the second comment /*Create if not found*/, in the installed shortcut.
9676.92
Script for assigning "Magenta" color to selected faces.
/* Assign selected faces to style = Magenta */ var starting_selection = moi.geometryDatabase.getSelectedObjects(); var faces = starting_selection.getFaces(); moi.geometryDatabase.deselectAll(); faces.setProperty( 'selected', true ); var style = moi.geometryDatabase.findStyle( 'Magenta', false /*Create if not found*/ ); if ( style ) { moi.ui.propertiesPanel.editStyleIndex( style.index ); } moi.geometryDatabase.deselectAll(); starting_selection.setProperty( 'selected', true );
"Magenta" can be changed to any color from the existing styles.
Show messages:  1-13  14-33  34-53  54-73  74-92
