Color Gradient script?
 1-2  …  23-42  43-62  63-82  83-92
Hi all,
Maybe some of you have noticed that the superb Gradient script uses 0-100 percent for hue (H)
instead of the commonly used 0-360 degrees for hue (H). So, to choose colors from a reference
image or palette you may do the following, as I currently do:
Look at an online site for RGB to HSV or HSB conversion or check the color palette in your Graphics
Editor and choose the HSV or HSB color there.
Then simply calculate the correct values for Hue = n for the script like: n/360*100 wich gives you for
example 70.83. In order to input these values in the script I have changed line 19 and 30 in the .html file to:
'NumericInput' instead of 'IntegerInput' and add 'style="decimalPlaces:2"' behind 'default="100"'
Hope you find this little tip useful.
EDITED: 14 Feb 2020 by STEFAN
9676.64 In reply to 9676.63
Can you post the file modified ? That will avoid some trivial errors! :)
not sure if this is a good idea ... but here is a picture.
modified-html
9676.66 In reply to 9676.65
OK that is more clear! :)
9676.67 In reply to 9676.63
Hi Stefan, I've updated the attached versions to take a hue value between 0 and 360 so you can use these ones without doing any converting.
EDITED: 15 Feb 2020 by MICHAEL GIBSON
*thanks a lot, much appreciated!!!* :-)
Best regards
Must make a new translation! :)
And of course with exactly same regulates!
French version will be done in a few time! (I must go to eat :)
@ Michael : Just a little detail :)
with the new 360 option you must erase this internal rectangle in the English "360" original! ;)
EDITED: 15 Feb 2020 by PILOU
French version done with the 2 possibilities
H 0 -100 or 0 - 360 :)
http://moiscript.weebly.com/deacutegradeacutes.html
9676.73 In reply to 9676.67
Awesome stuff! Such a cool thread :)
Always fun :) And thx to Max Smirnov for its incredible Subdivision, Split, Bridge, Scale !
Explode Move an Hidden Function By Michael
9676.75 In reply to 9676.71
Oops, looks like I forgot to remove that on the Path one. I've updated the attachment at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9676.67
Thanks, - Michael
9676.76 In reply to 9676.74
Looking delicious Pilou :) <3
What is the Hidden Function script?
9676.77 In reply to 9676.76
The hidden function is "ExplodeMove" native you must Press Tab and write it (with any capitals (so EXplodeMOVe is valid) but without Spaces! ;)
You can also make a shortCut
And it's present also if you have installted the List Scripts/Commands helper...for me the more speedy trick! ;)
ExplodeMove is in Max's CustomUI, at the top of his Scripts menu.
9676.79
Is there some way that a version of the Color Gradient script could apply its effect to the vertices of a obj export (file)?
9676.80 In reply to 9676.79
Hi Mindset,
Sorry no there isn't any way to set them individually, faces in .obj export will inherit the color of the surfaces they were generated from.
To manipulate individual mesh vertices you would need to do that in a polygon mesh editing program.
9676.81
Hi.
Please tell me how to assign hotkeys for the following actions:
1. Assign a fixed color to selected curves?
2. Assign a fixed color to all curves?
The color will be assigned in advance in the script:
"var red = XX, green = XX, blue = XX"
For version 3.0
All gradient scripts are very cool, but sometimes I need to quickly assign a color with hotkeys to individual curves or all curves.
I understand that the script will be like this:
"script: / * Assign styles to solids * / var styles = moi.geometryDatabase.getObjectStyles (); var breps = moi.geometryDatabase.getObjects (). getBReps (); var style_index = 0; for (var i = 0; i <breps.length; ++ i, ++ style_index) {if (style_index == styles.length) {style_index = 0;} var brep = breps.item (i); brep.styleIndex = style_index;} "
only for a single color and only for curves.
tried to edit this script, but I lack knowledge of syntax)
9676.82 In reply to 9676.81
Michael provided code for changing styles, used in the script for Jacobian function graph script, a few years ago. Do not know if you already have all of the code.
-Brian
Show messages:  1-2  3-22  23-42  43-62  63-82  83-92
