Color Gradient script?
 1-17  18-37  38-57  58-77  78-92
Michael, These Gradient scripts will be very useful. Thank you.
I've added both scripts to Max's CustomUI extension, under the scripts icon
Maybe someone could to a nodeeditor version, and find additional ways to select the two initial colors.
9676.59 In reply to 9676.57
> Ctrl + A ok, Rectangular Selection ok, Click on an object ok = selection following filters selected
> but what do you mean by only "Click on the viewport" ?
Same as what you say there for "click on an object".
Thank you Michael,
it is working now.
Best regards
Terrific of simplicity and very efficient!
Working on a loxodrome sphere. :-)
loxodrome
The gradient script is awesome!!!
Hi all,
Maybe some of you have noticed that the superb Gradient script uses 0-100 percent for hue (H)
instead of the commonly used 0-360 degrees for hue (H). So, to choose colors from a reference
image or palette you may do the following, as I currently do:
Look at an online site for RGB to HSV or HSB conversion or check the color palette in your Graphics
Editor and choose the HSV or HSB color there.
Then simply calculate the correct values for Hue = n for the script like: n/360*100 wich gives you for
example 70.83. In order to input these values in the script I have changed line 19 and 30 in the .html file to:
'NumericInput' instead of 'IntegerInput' and add 'style="decimalPlaces:2"' behind 'default="100"'
Hope you find this little tip useful.
EDITED: 14 Feb 2020 by STEFAN
9676.64 In reply to 9676.63
Can you post the file modified ? That will avoid some trivial errors! :)
not sure if this is a good idea ... but here is a picture.
modified-html
9676.66 In reply to 9676.65
OK that is more clear! :)
9676.67 In reply to 9676.63
Hi Stefan, I've updated the attached versions to take a hue value between 0 and 360 so you can use these ones without doing any converting.
EDITED: 15 Feb 2020 by MICHAEL GIBSON
*thanks a lot, much appreciated!!!* :-)
Best regards
Must make a new translation! :)
And of course with exactly same regulates!
French version will be done in a few time! (I must go to eat :)
@ Michael : Just a little detail :)
with the new 360 option you must erase this internal rectangle in the English "360" original! ;)
EDITED: 15 Feb 2020 by PILOU
French version done with the 2 possibilities
H 0 -100 or 0 - 360 :)
http://moiscript.weebly.com/deacutegradeacutes.html
9676.73 In reply to 9676.67
Awesome stuff! Such a cool thread :)
Always fun :) And thx to Max Smirnov for its incredible Subdivision, Split, Bridge, Scale !
Explode Move an Hidden Function By Michael
9676.75 In reply to 9676.71
Oops, looks like I forgot to remove that on the Path one. I've updated the attachment at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=9676.67
Thanks, - Michael
9676.76 In reply to 9676.74
Looking delicious Pilou :) <3
What is the Hidden Function script?
9676.77 In reply to 9676.76
The hidden function is "ExplodeMove" native you must Press Tab and write it (with any capitals (so EXplodeMOVe is valid) but without Spaces! ;)
You can also make a shortCut
And it's present also if you have installted the List Scripts/Commands helper...for me the more speedy trick! ;)
Show messages:  1-17  18-37  38-57  58-77  78-92
