Color Gradient script?
 1-4  5-24  25-44  45-64  65-84  85-92
Michael did an outstanding job, by providing two solutions! :-)
So now we have total flexibility. :-)
But don't forget when not giving names to objects IIRC it can
happen in some 3D apps, you import to, that they get confused
with color assignments, when no object names are given.
EDITED: 11 Feb 2020 by STEFAN
@ Michael How gradient numbers colors itselve are made following the path ?
Following the number of objects selected or following an arbitrary number (eg 100) ?
EDITED: 11 Feb 2020 by PILOU
I find it excellent to have the named objects option, besides paths,
to create then solids for 3D printing etc. :-)
test1
9676.48 In reply to 9676.47
Yes naming can be useful for particular material things! :)
Little bug for CreateGradientStyleAlongPath
I wanted to see what was the result for only one object selected! :) If it will be start color or end color...
My object is a simple Sweep
9676.50 In reply to 9676.38
Hi Stefan,
> But I must admit I don't know how to set up a correct shortcut to trigger the command. :-(
> I remember that from v3 with other scripts, but now with v4 I am lost, even if the UI is the same.
Did you get this figured out?
To set up the shortcut key, go to Options > Shortcuts, then click the "Add" button to add in a new one.
A dialog box will pop up that says "Press shortcut key:" - now you need to press the key combination that you want to use for the shortcut key. So for example if you want it to be triggered with Ctrl+G hold down the Ctrl key and push G, the dialog should then show "Ctrl+G" in it. Then push OK.
Then click in the right-hand "Command" column for the new entry in the list and put in the command you want triggered. For these new ones the command would be CreateGradientStyles or CreateGradientStylesAlongPath.
9676.51 In reply to 9676.40
> Does it possible to have something for restore the Default Style that we have when we launch Moi ?
> (seven colors Black, Red, Orange, Green , Cyan, Blue, Magenta)
Yes, using File > New will do that.
9676.52 In reply to 9676.46
It is assigned by taking the center of the object's bounding box and then finding the closest point on the path curve to that center point.
Then the parameter value of that point along the curve becomes the parameter for the gradient, with the start of the curve being the start color, blending up to the end of the curve being the end color.
9676.53 In reply to 9676.49
Yes only one object is not supported for the gradient. So don't do that. ;)
9676.54 In reply to 9676.51
<<> Does it possible to have something for restore the Default Style that we have when we launch Moi ?
<<< Yes, using File> New will do that.
Yes but i want keep that is on the screen and don't want close the actual file...
Just remake the original Style by default after any gradients
Maybe a script if you can't make an option
or a selection multiple for erase something large!
...and how works the filter? (Ctrl + Click)
9676.56 In reply to 9676.54
What about select what is on your screen, use Ctrl+C , then File>New, then Ctrl+V ?
That restricts object selection to only work on the filtered items. So for example if you set the filter on Style = Red, then when you click in the viewport (or do any selection action like Ctrl+A or whatever), only objects that have Style = Red assigned to them will be targeted for selection and any other objects not matching the filter will be skipped over.
9676.57 In reply to 9676.56
<< What about select what is on your screen, use Ctrl+C , then File>New, then Ctrl+V ?
Ok above + new file keeps the colors used for the objects created! Cool!
<< when you click in the viewport (or do any selection action like Ctrl+A or whatever)
it's that i had forgotten!
Ctrl + A ok, Rectangular Selection ok, Click on an object ok = selection following filters selected
but what do you mean by only "Click on the viewport" ?
Michael, These Gradient scripts will be very useful. Thank you.
I've added both scripts to Max's CustomUI extension, under the scripts icon
Maybe someone could to a nodeeditor version, and find additional ways to select the two initial colors.
9676.59 In reply to 9676.57
Same as what you say there for "click on an object".
Thank you Michael,
it is working now.
Best regards
Terrific of simplicity and very efficient!
Working on a loxodrome sphere. :-)
loxodrome
The gradient script is awesome!!!
Hi all,
Maybe some of you have noticed that the superb Gradient script uses 0-100 percent for hue (H)
instead of the commonly used 0-360 degrees for hue (H). So, to choose colors from a reference
image or palette you may do the following, as I currently do:
Look at an online site for RGB to HSV or HSB conversion or check the color palette in your Graphics
Editor and choose the HSV or HSB color there.
Then simply calculate the correct values for Hue = n for the script like: n/360*100 wich gives you for
example 70.83. In order to input these values in the script I have changed line 19 and 30 in the .html file to:
'NumericInput' instead of 'IntegerInput' and add 'style="decimalPlaces:2"' behind 'default="100"'
Hope you find this little tip useful.
EDITED: 14 Feb 2020 by STEFAN
9676.64 In reply to 9676.63
Can you post the file modified ? That will avoid some trivial errors! :)
Show messages:  1-4  5-24  25-44  45-64  65-84  85-92
