Boolean issue
All  1-4  5-8
9674.5
There is a handy merge command that is useful for joining edges that are already part of a solid object. Sometimes this simplifies things, so worth checking out.
9674.6 In reply to 9674.5
TIL about the merge command... wish I had known about this a year ago. That's what I get for not reading about commands with no UI button. Thanks nameless!
9674.7 In reply to 9674.1
Hi Charlie, it seems to be a glitch in the display mesher on the top face. Your actual model seems to be ok, if you go to export it out it should export ok the bug looks to be only in the display of it.
I'll put it on my list to investigate to see if I can improve the display for this case.
Just rotate all the cylinders for "unaxe" the curve generator before the boolean Diff and all will works fine! ;)
I have remarked that many many times!
EDITED: 3 Feb 2020 by PILOU
Show messages: All  1-4  5-8
