Assembly features (ala Modo or Houdini HDA)
All  1-4  5-9
9669.5 In reply to 9669.3
The above fix is for the second one for Macros.
The other one looks like that uses a JavaScript feature that works with MoI version 4's newer JavaScript engine but not with the older one used by MoI v3. So you'll probably have to remove that one to run in v3.
9669.6 In reply to 9669.4
thanks for the link. it solved the issue with the Macro.
And the Fillet2 missing must be resolved by the link of James given by Michael above...
9669.8 In reply to 9669.7
"Fillet2" node can be found in Construct2 menu.
9669.9 In reply to 9669.8
Yes :)
And the all new nodes should be in a new section because soon list will be to long to take place on only one screen height!
Show messages: All  1-4  5-9
