[NodeEditor] How i can Filet / Chamfer Points (corners) from a Rectangle Node ?
 1-10  11-30  31-39
9666.31 In reply to 9666.30
Thanks Michael
didn't think of that it works as required.
Any pointers for the notes node I could try ?
Barry
9666.32 In reply to 9666.31
Hi Barry,
It's not a node but here is a plug-in command that will allow you to set/retrieve notes text that will get stored inside the .3dm file.
9666.33 In reply to 9666.32
the photo was created using the macro to illustrate the kind of thing I mean (without the input nodules).
Barry
9666.34 In reply to 9666.33
Hi Barry, sorry I don't know enough about the node editor to be able to help you with that.
9666.35 In reply to 9666.25
Hi Barry:
In response to:
""I think a node for notes would be a good idea to give some reference rather than adding a separate text file.""
One good thing about using nodes>extensions>Documentation is that multiple languages are supported.
So far only EN and FR, as far as I know.
Although only very few nodes have any such Documentation at present. I did 2 or 3, just to learn how to do it, quite a while ago.
I do not know how to do the messaging that you have suggested.
The messages would have to be stored somewhere.
So maybe have the message node access the Doc somehow?
9666.36 In reply to 9666.25
Here is chamfer3 node, modified from r2d3 fillet2 node. (r2d3.js is the location of the Construct2>fillet2 node.)
It is placed in the construct2 menu.
Michaels factory input post was used to modify the inputs.
I did not make any provision for factory input 1 boolean true, Do straight corners (only applies to brep filleting). ( IT IS SET false.)
Nor is factory input 2 utilized. (list of bool - Corners - If filleting a single multi-segment curve, list of corners true = fillet this corner. (WHATEVER that means :-))
(factory input 2 is commented out.)
Example node program:
Star node, Extrude node ( Extrude more than sum of both chamfer distances), Chamfer3 node, (OR Fillet2 node), Output node.
(So the Star is a 3D solid.)
(limited testing)
(So I guess there is no setup for chamfer of curves ???, or maybe there is, have to do more testiing with star outline curve(s).)
Maybe the other various fillet nodes could be modified to do the chamfer of curves?
Deleted this old attachment, for space.
EDITED: 17 Jan 2025 by BEMFARMER
9666.37 In reply to 9666.36
thanks for chamfer3 node works ok but distance 2 not working ?
Still useful thanks.
Barry
9666.38 In reply to 9666.37
Could be some error or omission. Past midnight, I'll take a look tomorrow.
-Brian
Edit: It is not supposed to chamfer a solid with 2 different distances.
EDITED: 15 Mar 2022 by BEMFARMER
9666.39 In reply to 9666.38
Spent about an hour looking for errors.
Did not find any.
Finally tried to Chamfer the extruded star with MoI regular Chamfer command. It DOES NOT do two distance fillet on the extruded star.
So Chamfer3 is working as well as its incomplete programming can do.
A star border curve CAN be Chamfered with two distances in MoI.
So it should probably be considered an incomplete node, that only works on solids(?)
This Chamfer3 script is not multi-process, and does not do curves.
Other, less old Chamfer scripts, can chamfer a star border curve, with two distances.
- Brfian
Show messages:  1-10  11-30  31-39
