Scripting Question about creating files
All  1-5  6-14
9665.6 In reply to 9665.5
Thanks for the tips, Larry! I will spend more time poking around in the commands directory and reading the release notes in more detail.
9665.7 In reply to 9665.4
Hi Teddy, there is also some info here but not much sorry:
http://moi3d.com/wiki/Scripting
9665.8 In reply to 9665.7
Going through existing scripts from others has been very helpful.
What version of the Javascript/ECMAScript interpreter is built into MOI? I've found that newer language features like the "for-of loop" don't seem to be supported.
Teddy
9665.9 In reply to 9665.8
I believe it is ECMAScript5 = ECMAScript2009 = Javascript5 = ES5
Babeljs.io can be used online to convert ES6 to ES5. Use the "try it out" tab.
ECMAScript6 has the confusing year 2015 name.
ECMAScript6 has "let" and (weird to me) function naming, and weird double arrows. And I think Cosh() and Sinh().
9665.10 In reply to 9665.8
Hi Teddy, yes I think it only supports ECMAScript5 like Brian writes above.
The interpreter is JavaScriptCore that comes with QtWebKit with Qt 5.4.1 .
9665.11 In reply to 9665.10
I wanted to use Math.js for complex numbers and elliptic functions, and possibly other functions, but notice that it is
at least ES6 (ECMAScript 2015. Do you think MoI v5 may have ES6 or later compatibility?
I guess I can translate some of Math.js to ES5...
9665.12 In reply to 9665.11
Hi Brian, it will take quite a bit of work to update the scripting engine so I'm not sure when that could happen. Probably not for MoI v5.
9665.13 In reply to 9665.12
Thank you Michael.
EDITED: 7 Dec 2020 by BEMFARMER
Message 9665.14 deleted 7 Dec 2020 by BEMFARMER
Show messages: All  1-5  6-14
