Scripting Question about creating files
All  1  2-14
9665.2 In reply to 9665.1
Hi Teddy, yes there is a way for a script to read and write to a text file. This is done with moi.filesystem.openFileStream( filename, mode ).
moi.filesystem.openFileStream takes 2 parameters, a file name and the mode which is either 'r' for read or 'w' for write. Check out the updated version of SavePointFile (the one that says it works on Mac) for an example: http://kyticka.webzdarma.cz/3d/moi/#SavePointFile .
The Filestream object has these functions:
.readLine() - reads a line of text from the stream, the text is the return value of the function.
.writeLine( text ) - writes a line of text to the stream.
.atEOF property - returns true if the stream is at the end with nothing more to read from it.
.close() - closes the stream.
.setWriteBOM( ) - sets whether to write the byte order mark at the front of the text file, default is no BOM.
.setCodec( name ) - controls the encoding to use for reading or writing. Supported codecs are listed here: http://doc.qt.io/qt-5/qtextcodec.html#details .
> Q: is there a way to embed data such as the array of saved views directly into a 3DM file?
Sorry, no - currently there isn't really a proper way for a script to embed its own data into a 3DM file.
9665.3 In reply to 9665.2
Thanks, Michael! I appreciate the details about the filestream and I will check out the example scripts.
- Teddy
9665.4
Is there some documentation somewhere that might help me learn the underlying Javascript API? I've taken a look at http://moi.maxsm.net/api/ but it seems like it's probably a subset of the actual functionality. I was hoping there was some kind of documentation or API reference that might be more comprehensive.
I appreciate all of your work on MOI and documentation is probably one of the last things on your mind but if you can point me in the right direction, I'd very much appreciate it.
- Teddy
EDITED: 21 Oct 2020 by TEDDYLINDSEY
9665.5 In reply to 9665.4
There isn't really a current API guide, but I've found studying Michael's code (particularly the .js and .htm files in MoI's commands directory) to be quite helpful in developing a sense of how the API works. The v3/4 release notes also contain numerous hints about scripting and the API as do the forum posts.
v3 release notes: https://moi3d.com/wiki/V3Beta
v4 release notes: https://moi3d.com/wiki/V4Beta
--Larry
9665.6 In reply to 9665.5
Thanks for the tips, Larry! I will spend more time poking around in the commands directory and reading the release notes in more detail.
9665.7 In reply to 9665.4
Hi Teddy, there is also some info here but not much sorry:
http://moi3d.com/wiki/Scripting
9665.8 In reply to 9665.7
Going through existing scripts from others has been very helpful.
What version of the Javascript/ECMAScript interpreter is built into MOI? I've found that newer language features like the "for-of loop" don't seem to be supported.
Teddy
9665.9 In reply to 9665.8
I believe it is ECMAScript5 = ECMAScript2009 = Javascript5 = ES5
Babeljs.io can be used online to convert ES6 to ES5. Use the "try it out" tab.
ECMAScript6 has the confusing year 2015 name.
ECMAScript6 has "let" and (weird to me) function naming, and weird double arrows. And I think Cosh() and Sinh().
9665.10 In reply to 9665.8
Hi Teddy, yes I think it only supports ECMAScript5 like Brian writes above.
The interpreter is JavaScriptCore that comes with QtWebKit with Qt 5.4.1 .
9665.11 In reply to 9665.10
I wanted to use Math.js for complex numbers and elliptic functions, and possibly other functions, but notice that it is
at least ES6 (ECMAScript 2015. Do you think MoI v5 may have ES6 or later compatibility?
I guess I can translate some of Math.js to ES5...
9665.12 In reply to 9665.11
Hi Brian, it will take quite a bit of work to update the scripting engine so I'm not sure when that could happen. Probably not for MoI v5.
9665.13 In reply to 9665.12
Thank you Michael.
EDITED: 7 Dec 2020 by BEMFARMER
Message 9665.14 deleted 7 Dec 2020 by BEMFARMER
Show messages: All  1  2-14
