V4 beta Jan-22-2020 available now
 1-9  …  50-69  70-89  90-109  110-129  130-149  …  170-178
9660.90 In reply to 9660.88
Should there be an indicator, say ~, before the less accurate number? :-)
(asked partly in jest)
Don't know if this question have been send before.
I like the possibility to import OBJ in V4beta.
But it's linked to a subd operation next.
Of course we can use a separate script to import OBJ,
but if we could avoid the subd operation in native V4, it would be cool.
Have a good 3D !
9660.92 In reply to 9660.91
Hi Phiro, sorry no I'm not expecting to have that kind of non-sub-d .obj import. The problem is that NURBS solids are not intended to be made up of say a hundred thousand little tiny flat faces. There is some overhead in how NURBS surfaces represent faces with an "underlying surface" and then trim curves that mark areas of the surface as active or holes. So each surface in a NURBS solid is more complex (but can do more) than a polygon in a poly modeling program. A model with a hundred thousand little tiny flat surfaces is very heavy and unwieldy when represented as a NURBS object.
A NURBS model should have larger smooth surfaces in it, like a sphere for example should be just one exact sphere surface with a trimming boundary on it, not a whole lot of little flat facets.
If you have an .obj file that you want to edit as polygons, then MoI is just not the right tool to use for that job. It is not designed to work with that type of model structure. You should be using a polygon mesh modeling program to work on that kind of data, it will not work well with MoI.
Since sub-d smoothing generates larger smooth surfaces, it's the type of import that does fit ok.
thanks for your answer Michael.
9660.94
Any idea when we will be able to see the new dimensions in PDFs? If I recall, you still have another beta release in mind, might this make it into that beta? If so and if soonish, I will prefer to use your new dimensions, but will otherwise use Max's Dimensions plugin as the PDF export looks better. I haven't been able to make the clipboard export look as nice as the PDF export (mainly resolution). Many thanks for all the effort you've put into MoI!!
--Larry
9660.95 In reply to 9660.94
Hi Larry, soon I hope. That is one of the last remaining areas left to do though. I've just about got my board cleared of bug fixes and should be able to focus on finishing up dims.
It's definitely a target for this next (and last?) v4 beta.
9660.96 In reply to 9660.92
Hi Michael, is there a difference in installing CustomUI in v3 and v4? I know this is most probably error in my side but I can't seem to get CustomUI working correctly in v4 January Beta but it works great in v3. Also I'm using the dark gray theme with the custom ui bar.
Edit: sorry just additional info to clarify: The CustomUI shows fine on the v4 interface, but Obj Library and Scripts does not list anything. Scripts and Object library shows up fine in v3
EDITED: 22 May 2020 by APHAITS
9660.97 In reply to 9660.96
For my Windows 10 setup, AppData/roaming folder has a copy of the Objects folder, for MoI4beta, and also has a Commands folder with "non-standard extra scripts", mostly with a _ prefix. (_ prefix is not needed.)
The "standard" regular MoI4beta commands are in the C:\Program Files \MoI4beta... directory.
MoI3 files are under Program Files (x86), with their own copy of Objects folder and All commands.
9660.98 In reply to 9660.96
Hi aphaits,
Yes, there is a different version for v4, there is a link to it at:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
It is meant to be installed in AppData rather than in the install folder.
What version of CustomUI are you using on v4, is it the one made for v4 or the one for v3?
9660.99 In reply to 9660.98
Yes I've used the same link:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.268
Moi3d v3 I used CustomUI 1.03 with Dark Gray Theme for 3.0
Moi3d v4 beta I used CustomUI 2.0 Beta 2 with Dark Gray Theme for 4.0 beta
Tried fresh v4 install without dark gray theme and it has the same list problem.
When installing in AppData folder, does all three folders go there? or only startup folder contents?
I've attached screenshots:
v3 Ext Scripts List Works
v3 not sure how lighting script works
v3 Obj Library List Works
v4 Ext Scripts List Both Empty
v4 lighting doesnt show a message
v4 node edit and log button shows empty windows
v4 Obj Library List Empty
v4 subdiv script seems to be missing
9660.100 In reply to 9660.97
I'm using windows 10 and when installing with default settings, v4 installed in Program Files, v3 installed in Program Files (x86)
Tried copying commands, objects, and startup folder to appdata/roaming/moi, but there's no change. Still nothing on the list rollout.
9660.101 In reply to 9660.99
Hi aphaits,
Yes, you'll need to copy all three folders over there so you should have:
appdata/roaming/moi/objects
appdata/roaming/moi/customui
(Note, not nested inside startup)
Both of those will be new directories that did not previously exist inside appdata/roaming/moi/ .
For startup there will be an already existing startup folder in appdata/roaming/moi/startup, copy the contents of the startup folder from the .zip file into appdata/roaming/moi/startup .
If you only copy the startup scripts and not "objects" or "customui" then you'll get most of the problems you describe.
The menu for these are inside the customui folder, if it was not copied over you will get this result.
Same thing here, the menu is inside the customui folder and so if you did not copy the customui folder over you will get this result. In order to use this extension though it depends on a section of your moi.ini file to have been populated with lighting settings from a separate older plug-in. To make it work, install the Lighting Options plugin from here and run it: http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.43 that should then fill in the section of moi.ini that the CustomUI lighting menu is looking for.
Node editor needs to be installed separately to appdata/roaming/moi/nodeeditor for it to work, you can get it at http://moi3d.com/wiki/nodeeditor, get the one labeled "Most recent version with new extensions collected by James here".
The dialog for the Log button is in the customui folder so it needs the customui folder to be copied over.
It requires the objects and customui folders to be copied over, if not you'll get the result you show.
It needs to be installed separately, go to http://moi.maxsm.net/media/files/ and get Subdiv_beta9.zip, unzip and copy the 2 files _Subdiv_beta9.htm and _subdiv_beta9.js into the appdata/roaming/moi/commands folder and that will make that command available and it will then run when you push that button.
Some other ones that also are installed separately are Bridge, Split, Scale, and ImpObj. You can get those at http://moi.maxsm.net/media/files/, look for:
sSplit.v.0.95.2015.08.10.zip
sBridge.v.0.71.2015.03.26.zip
sScale.v.0.6.2015.03.28.zip
ImportObj.v.1.5.2015.09.10.zip
Unzip and put the contents inside appdata/roaming/moi/commands .
Let me know if you are still seeing any problems.
EDITED: 24 May 2020 by MICHAEL GIBSON
The cool thing for Moiv4beta is that once "appdata" is set up properly, new beta updates
utilize it, and presumably the final Moi4 release.
-Brian
For the extra scripts, note that the ones without the underscore "_" prefix appear at the tail end.
9660.103 In reply to 9660.101
Thank you very much Michael!
Everything works great!
Still have a lot to learn using some of the scripts, but everything seems to be working.
9660.104
any option to select from right to left to act the same as left to right ?
95% of the cases I'm selecting individual components & a lot of times I have to hide geometry/surfaces to select desired curves/construction
9660.105 In reply to 9660.104
Hi Cemortan_Tudor, if you don't have a convenient open area to initiate a selection rectangle you can hold down Shift+Ctrl which will force window selection to happen. It won't try to do click selection when Shift+Ctrl is down so it isn't necessary to hide objects if you use that method.
But there is also an option in moi.ini that controls how window selection works. It's in moi.ini under:
[Selection]
WindowSelectMode_Combo_Intersect_Contained=Combo
If you set that to =Intersect it will always use the dashed outline "crossing" method (right-to-left in Combo mode) where anything that intersects the selection rectangle will be targeted.
If you set it =Contained it will always use the solid outline (left-to-right in Combo mode) where only things that are completely contained inside the selection rectangle will be targeted.
Hello Michael.
How are you? I hope all is ok for you.
Just a banal question :)
When you'll publish the official final release of V4?
Are you working on some specific area yet?
Thanks and have a nice day.
9660.107
Hi Michael !
can u update geometry factories on http://moi.maxsm.net/api/ ?
9660.108 In reply to 9660.106
Hi Marco,
Soon I hope, but I don't have a specific date yet.
Yes, there is still a little work to do to finish up dimensions.
9660.109 In reply to 9660.107
Hi Cemortan_Tudor,
Sorry, no I cannot. That isn't my web site.
Show messages:  1-9  …  30-49  50-69  70-89  90-109  110-129  130-149  150-169  170-178
