V4 beta Jan-22-2020 available now
 1-12  13-32  33-52  53-72  73-92  93-112  …  173-178
9660.53
If I offset just 1 polyline I get the same issues. So it's not related to complexity. Try the dxf and you'll see.
9660.54 In reply to 9660.53
Hi Yanik,
I am seeing some issues with polylines that are at shallow angles to one another.
In general MoI is not expecting to work with polylines like that which have numerous line segments at shallow angles to one another, it's expecting for things shaped like that to be smooth curves and not polylines.
9660.55 In reply to 9660.46
I'm not sure I understand, shouldn't the dimension display units be independent of the model's?
Hobbit's foot are something else than 12 inches? :)
Marc
9660.56 In reply to 9660.54
This curious thing of looping was due of an old version of Fatlines!
with the FatLines for v4 no more looping! : even with the DXF above post! ;)
Lignes Epaisses = FatLines
EDITED: 24 Feb 2020 by PILOU
9660.57 In reply to 9660.53
Here is a result I made. 3 or 4 lines are missing, but it could have been dealt with. A little more than just 1 click though.
Since you want to keep the breakpoints of the polylines, that is what kindof makes the offsetting hard.
So I joined and rebuilt the original file (Rebuild to remove all the corner points)
Then I extruded the new curves and shelled them on centerline. I could then Boolean together the shelled solids into a single solid.
(This is where I lost 4 lines. they would need to be addressed at the extrusion level to get good solids to bool)
From the single solid, I can extract the bottom edges to create the thickened curves.
I can now bring in the original file and extract the points I wanted to keep (As waypoints I guess?)
Anyway, I can make a video if this file looks like what you are after and you wanted to see more.
EDITED: 27 Nov 2020 by BURRMAN
The curious is the FatLines works fine with only certain measures of lines...
9660.59
Not sure if rendering bug or performance optimization:
9660.60 In reply to 9660.59
Hi Andre, it's kind of both. It's a known rendering bug but it has intentionally not been fixed as of yet since the fix could cause some performance degradation for all curve drawing.
See here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4101.2
At some point I should be able to do a careful fix but I'm not sure exactly when. Thanks for reporting it.
9660.61
HI Michael,
Really enjoying the DIMS function in MOI great for quick markups. Here is one example if possible to add a dimension style where the dimension sits outside to the side of the lines dimensioned area. In areas where mixing large scale and small scale dimensions would be good so its still legible.
EDITED: 20 Sep 2020 by ALEXPOLO
9660.62 In reply to 9660.61
Hi Alex, in the Jan-22-2020 v4 beta there is now an option for putting the arrows to the outside like you want there.
It's under Arrows > Position = "Outside" , and also when it is set some additional options for "Outside line length" and "Draw line across" will appear in the "Dim lines" section:
It does not try to place the text to the outside but (it looks like you've seen this already) you can turn on edit points for a dim with Edit > Show pts and then drag the point for the text to position it off to the side where you want it.
You can set Arrows > Position = "Outside" on an individual dimension by using the "Details..." button in the object properties that shows up for the selected object, or also set it as a preset under Options > Dimensions, then select that preset when you initially draw the dimension.
Let me know if that was not what you were looking for.
9660.63
Thanks for the tip with Arrow heads - with the DIM type I did that in Photoshop is that possible to achieve in MOI also?
regards
Alex.
9660.64 In reply to 9660.63
Hi Alex, yes it's possible to do that in MoI now. You would set the arrow position to "Outside", and also turn on points for the dimension and drag the text point off to the side.
Here's a demonstration:
9660.65
WOW! that really takes the dimensioning to the level of producing easily read drawings.
Looking forward to final release with PDF and DXF export capabilities - at the moment just taking screen shots and thats good enough to them them over line.
I guess your user guide once its already will demonstrate these capabilities.
thanks
Alex.
9660.66
Mi Michael,
Great work!
I see you added a lot of items into MoI since beta I've used.
I modified some stuff in moi.ini and was wondering what would happen if I overwrite my old .ini file to latest beta.
Is there any way someone can import custom settings from old .ini to the new version?
Or do I have to do a text comparison in some 3rd party tool and put together .ini file that would work?
Thanks a lot
Juraj
9660.67 In reply to 9660.66
Hi Mr. Yuri, it's no problem to use a previous moi.ini with a new beta. The new version will automatically write out any new settings that it uses. The new settings will start out with default values.
So you don't have to do any text comparisons or merging, just have the new MoI release use your previous moi.ini file and it will get new things added to it automatically.
If there is no moi.ini found at all, a new one will be created with default values. If there is an existing one, it will get used and new values will be added to it, with previous settings remaining the same and the newly added ones having default values.
9660.68 In reply to 9660.40
Wow...looks to be good. Maybe a game changer for me. I was able to import a model I created in 3D Coat as an obj
9660.69 In reply to 9660.68
You have 2 possibilities
_importObj by Max Smirnov http://moi.maxsm.net/files/scripts/ImportObj.v.1.5.2015.09.10.zip
and the SUbdiv / create from file native directly inside Moi by Michael
EDITED: 21 Mar 2020 by PILOU
9660.70 In reply to 9660.69
Thanks kindly, but I never understood on how to install plugins for MOI3D? It seems somewhat awkward.
Ken
9660.71 In reply to 9660.67
Hi Michael.
This is awesome.
Tried and seems to work.
Only my scene browser is really narrow now.
I had it almost double the size.
I tried to search ini for scene or browser but cannot find how to edit width.
Also searched forum but searching here is quite a pain and I didn't find it.
Regards,
Juraj
9660.72 In reply to 9660.70
"plugins" are commands not native generally in 2 files .js, .htm sometime with an image more .png...
that you just put inside the Moi commands folder...so one, two or three files...
then make a shortcut with _CMorph on the secound column, or Press TAb then write _Cmorph (with any capitals but without spaces)
Here for example the Cmorph by Max Smirnov from http://moi.maxsm.net/media/files/
inside the commands folder
and the result...a morphing between 3 curves (must be true curves "curvated" not straight polylines!)
For some "plugins"... so "commands" of Max Smirnov take a look at this page ;)
(in French but very illustrative ;)
http://moiscript.weebly.com/scripts-de-max-smirnov.html
Show messages:  1-12  13-32  33-52  53-72  73-92  93-112  113-132  …  173-178
