V4 beta Jan-22-2020 available now
 1-6  …  67-86  87-106  107-126  127-146  147-166  167-178
9660.107
Hi Michael !
can u update geometry factories on http://moi.maxsm.net/api/ ?
9660.108 In reply to 9660.106
Hi Marco,
> When you'll publish the official final release of V4?
Soon I hope, but I don't have a specific date yet.
> Are you working on some specific area yet?
Yes, there is still a little work to do to finish up dimensions.
9660.109 In reply to 9660.107
Hi Cemortan_Tudor,
Sorry, no I cannot. That isn't my web site.
9660.110 In reply to 9660.108
Ok Michael.
Thanks for the infos.
Have a nice day.
9660.111
Dude, I REALLY need dimensions to be printable - is there anyway you can give an ETA on printing/export support for dimensions?
9660.112 In reply to 9660.111
Hi TwinSnakes, soon I hope, but still a few days out at least.
9660.113 In reply to 9660.112
Thanks Michael, hope all is well with you. Havent checked in on you in a long while.
I had to get some Blueprints ready, ASAP - and Moi3D was soo much faster to work with compared to AutoCAD.
I went to print and *GASP* - well, you know the rest.
9660.114 In reply to 9660.113
Hi TwinSnakes, I'm working on it!
9660.115
Just gave the beta a spin on my Linux workstation and it works like a charm so far (fingers crossed). I am super impressed by the subd to nurbs option. Fast and results are really good.
On a linux side of things I've accidentally forgot to disable dxvk in the wine prefix... and to my surprise it didn't cause any issues so far. Will check out the built in hud to check whether dxvk is being used.
So in the next couple of days I'll be setting keys / macros then will try opening some heavier files from Rhino. If all goes well I'll finally have a proper nurbs sketching on my regular PC :) .
edit: one glitch I've found so far - sometimes when I hide browser tab MoI seem to be stuck with the selection on one of the objects in the scene, on the active layer. Thus I can't select / move etc other objects. When I open browser tab I can select etc again. Hide browser - can't.
EDITED: 9 Jul 2020 by PRZEMAS
9660.116 In reply to 9660.115
Hi Przemas,
This seems to have something to do with OpenGL on Linux getting confused in some way when the viewport windows get resized. I haven't been able to figure out why it's sensitive to that yet.
9660.117 In reply to 9660.116
ok, hope this one gets a workaround. I'm able to reproduce it a bit too easily - so will definitely have an impact on overall workflow.
Does not happen with v3.
Which API does MoI v4 use - OpenGL, DX ? And are there some config options to force a specific API? I'd like to tinker a bit as hopefully this one might have a workaround (like Nvidia triple buffering redraw bug).
9660.118 In reply to 9660.117
Hi Przemas, the Windows version of MoI will use Direct3D11 by default on Windows and OpenGL by default when running on Wine.
There is a setting in moi.ini you can modify to use a specific API:
[View]
GraphicsAPI=Direct3D11
or
GraphicsAPI=OpenGL
9660.119 In reply to 9660.118
yup, confirmed - happens with OpenGL renderer. Does not happen with DX11.
With forced DX11 I noticed that MoI starts correctly with DXVK. Sadly when you start adding / extruding geo visual glitches happen. Thus had to disable DXVK.
Still have hopes for that option as most of the times if I get the app working with DXVK I get the best performance and stability (Vulkan is awesome from end user point of view - but I totally get it how much more work it requires from dev side, one of the reasons I have my hopes in translation layers like dxvk).
edit: and with api set to DX11 the __GL_MaxFramesAllowed = 1 setting is not needed
edit2: another small thing I've found - in V4 selecting sub patches is trickier than in V3. For example on a cylinder to select a "cap" in V4 I need to really play with camera view position till it allows me to pick the cap. In V3 it works like a charm.
9660.120
HI Michael,
My Beta version of October has ended.
Should I download JAN-22 Beta?
And how can I export all my scrips, configs and shortcuts to newer version of Beta?
Thank you a lot.
Have a nice day !
K.
- Konni
Artstation Instagram V4 Beta Win 10
Size: 24.8 KB, Downloaded: 52 times, Dimensions: 526x282px
9660.121 In reply to 9660.120
Hi Konni, yes the Jan-22 beta does not expire until Sept 12, so you should download the Jan-22 to keep v4 running right now.
Your shortcuts and settings are stored in the moi.ini file in the appdata folder. The new beta will use the same moi.ini file and so those settings will automatically come over.
For scripts that you have added, it depends on how you added it. If you put them in the appdata commands folder then the new beta will find those there as well and you won't need to do anything more.
If you copied the scripts into the install commands folder, then you will need to copy those over so the new beta can find them. MoI will look for plug-in commands inside both the install's commands folder and also the appdata commands folder. I would recommend putting them in the appdata commands folder so new versions will find them there automatically.
On Windows you can find the MoI appdata commands folder by using Win+R to bring up the "Run" dialog and then put in %AppData%\moi\commands.
9660.122 In reply to 9660.121
Thank you very much for such informative and clear answer.
- Konni
9660.123
I just wanted to say, as a MoI user for some years, thank you. I have *only* ever used it to convert CAD files to LightWave objects - that was the main reason buying it, and it has done a great job. The beta v4 has been a great asset for larger file conversion.
But this is not why I'm saying thank you. I'm saying thank you because I have recently used it to help me with our industrial design projects. We're a small 3D design house, starting as 3D visualisers, but two of the main guys, myself included, are industrial designers by trade. We use Inventor for our CAD work, but I don't use it, having moved into 3D visualisation way back after uni. When it came to the concept design of a new organic product, my usual modelling tool, LightWave, was limiting what I could do. I downloaded Rhino, and the interface put me off immediately. I needed something that *looked* simple, all the tools were visible that I needed - no clutter to befuddle the newbie.
So I looked again at the MoI I had installed and, after a day or two, I managed to pull off the concept process with me feeling as though I had controlled the design rather than the software controlling it. Having the bug I am now carrying out some in-house projects with it - and I love using it! Snappy and responsive, and pretty intuituive.
So, thank you. When v4 comes out I'll definitely be getting it!
9660.124
We all are waiting for V4. I hope, it will come in the next time.
9660.125
Is there anyway to subscribe to a thread here, or some announcements thread so I can be notified when there is a release?
Is there some other social media vehicle I can subscribe too for release announcements, like Twitter, Facebook, etc?
...I just cant keep coming back here everyday like this to check.
9660.126 In reply to 9660.125
Seems last line of this section can do that you want...thread subscriptions...
https://moi3d.com/forum/user.php?webtag=MOI
Show messages:  1-6  …  47-66  67-86  87-106  107-126  127-146  147-166  167-178
